Old November 19th 2018, 21:15
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Balljoint beam thru rods?
Hello all,
Why do coil-over users go with thru rods in the front beam vs leaving the torsions in place and just removing the grub screw?
Kevin
Old November 20th 2018, 04:59
They are still locked in place even with no grub screw
Old November 21st 2018, 13:04
DORIGTT's Avatar
The leaves just 'add' to the spring rate then correct?
Old November 23rd 2018, 21:45
correct, the section that the leaves sit in is fixed
