Old March 11th 2003, 22:03
beachball6 beachball6 is offline
2332cc 65 looker
68 stock auto stick
i think i can beat your honda maybe...
Old March 11th 2003, 22:31
Question
It depends on the kind of bolts the wheels take. For example, the bolts (nuts) on a Porsche wheel are cupped, while a centerline wheel is flat.
Maybe someone who has done this before can help.
Old March 11th 2003, 22:50
what im trying to comprehen is do i need "press in studs" or what i dunno how that works this is my 1st custom wheel job.
shawn
searched through the fourm im going to get 14mm press in studs i just hope this fits the wheels.
shawn
2332cc 65 looker
68 stock auto stick
Old March 12th 2003, 00:56
chigger chigger is offline
If you are going to stub the rotors you can get the right nuts pretty easy. Using a hole in the rotor with a special screw is a whole lot harder to find. I don't know where you are getting your wheels, but the nuts that originally came with the wheels are the ones you need to use. I think studs are safer for high performance applications and if the musclehead at the tire shop cross threads it you can put in a new stud alot cheaper than buying a new rotor.
Old March 12th 2003, 07:35
i got rotors and drums from csp and bought studs from aircooled.net gonna c how this goes. the original ones for the wheel are in use still.
shawn
2332cc 65 looker
68 stock auto stick
Old March 12th 2003, 22:33
http://www.cbperformance.com/catalog.asp?ProductID=686 thats wat i got 12mm hope they work.....we will c soon enough...
shawn
2332cc 65 looker
68 stock auto stick
