Old April 24th 2003, 10:16
MattKab's Avatar
MattKab MattKab is offline
Question T4 'head flow characteristics/valve sizes
I have two pairs of T4 'heads. A pair of 021 101 371 S with 41*33mm valves. Also a pair of 071 101 371 A with valve sizes 40*33mm.
I may consider resizing the valves to suit my plans for a 2056 revving to little over 6krpm using a single TB and plenum behind a 911 fan.
Am I right in thinking that the exhaust ports on 021 heads are less restrictive than those on the 071, which look deeper?
What would be good valve sizes for my application?
Old April 29th 2003, 11:19
kdanie kdanie is offline
I would go with 44/36 valves, use 8mm stems on the exhaust. I would port the heads anyway so it doesn't really matter which casting you use. That's just me though....
ken
Old April 30th 2003, 00:44
chigger chigger is offline
I just read an 1974 article on the T4 heads on a racing Formula Vee. They were running a 1700 T4 and stated that the biggest problem with the heads was the exhaust port. It is too restrictive. I don't remember the valve sizes, but they went through some major work to get bigger exhaust ports. I think the engine ended up with 153 hp @ 6500 rpm. I had to give the magizines back so I can't look it up for you. You should see some of the prices for the products back then.
