traction bars
I am going to be putting together a traction bar in the near future to support the underside of my engine. Question:
do you weld the braces to the body or can you run it from the standard bumper mounts? The bumper mounts seem a bit far away, but I dont really want to weld to the car unless I have to. Anyone got any decent pics?? Thanx
1969 VW aka Suicyde www.geocities.com/suicyde_vw Tony__Z@hotmail.com |
Tony,
With traction bar I assume you mean somthing like the Kafer Cup Brace ? Typically these tie the shocktowers to the framehorns. I believe there are braces that connect to the body, but in general the comments are that eventually the body wiil flex or even tear becuase of the load. There is a tech article about the install of the brace on the site. I've never seen a bar that ties to the bumper mounts, and I agree with you that that seems quite a distance to cover...plus the bar has to go straight back from the horns, which probably doesn't give a lot of support.... HTH Rob. |
I know the bar you mean.
It has a pair of mountings which bolt onto the rear bumper mounts, you drop some threaded rod down from those and have a bar that runs from one side to the other, supporting the engine by its sump (or on a t4 it could bolt to the rear engine hangers). They do work, but you NEED to support the framehorns too. Cya, Sam C
1973 1303 (super beetle) in Jaguar British racing green, Raby 2270, B spec gearbox, Lots of carbon fibre, Wolfrace Octane Black 17x7.5, Goodyear Eagle F1's, Kerscher suspension front and rear, kamei airdam in carbon, corbeau seats, momo millunium steering wheel. CDT eurosport 6.5 front speakers, IDMAX 12D2 sub, rockford old school amps. |
i welded "L" brackets to the car. i also found that the bumper mounts were too far away.
'72 super '65 bus '52 split |
