Old September 13th 2004, 20:34
Gas front hood struts for 1303
I want to fit some gas front struts to my front hood, has anyone done this? Does anyone have part number or lenght needed? I went to local parts shop and gave me a photocopy of the page in his catolgue, its some involoved calculations, just being lasy.
Old September 13th 2004, 20:39
Superman
I've only seen them made for the Bug/1302 (which you also have Steve). German Car Company had them, not sure where to get them now.
Old September 14th 2004, 07:45
Hi Sup
The 1302 has been sold, Im going to work out the formula that they gave me at the parts shop, I will let everyone know what I find out, they are Munro Maxi Struts so they should be avaibale around the world.
Old September 15th 2004, 00:46
Superman
Yea I seen in the other post that you sold it
Let us know what you find out on those hood struts.
Old September 15th 2004, 04:25
starmember's Avatar
in holland thay are sold in the local bug shops
90 in to te corner.
Old September 15th 2004, 23:05
Superman
http://www.kevertuning.nl/Onderdelen...charnieren.htm
Old September 16th 2004, 02:39
starmember's Avatar
^^^== thanks.
90 in to te corner.
Old September 16th 2004, 10:04
I sent the an email, I will keep you all informed.
Old September 17th 2004, 04:37
starmember's Avatar
35 euro = 42.68250 US Dollar only that was by a other companie. I dont think they respont to youre e-mail. If zo i will call them for prices.
90 in to te corner.
Old September 17th 2004, 09:14
They replied to me. They told me they would cost 55 euro A set?
Old September 17th 2004, 20:11
onixbonilla's Avatar
onixbonilla onixbonilla is offline
Are these special build items or just came from other car?If so from which one? By the way this company have some ineteresting things such as the adapter for use the bilstein beetle streering damper of a beetle on a super. Also the Remmele type side air intakes.Will they send to USA?
Onix
Old September 29th 2004, 05:44
Superman
I've never seen those gas hood struts for a 1303, just Standard and 1302, so it would be nice if they do indeed make them.
Old September 29th 2004, 08:34
The reason I want to get them is that the stock spring sometimes goes a bit wayward and this pops the circlip off the hinge and makes the whole thing fall down and crash into the body, not a good look.
I have the formula but Ive been too lazy to work it out. I need to measure the weight of a stock hood and then do some measurments of the pivot points. I will make it my mission before I go away on hols.
Old September 29th 2004, 13:55
Michael Ghia's Avatar
Struts
Anyone get anywhere with this yet?
I'm looking into fitting a pair to the family 1303LS Cab....
I'd be really good if there was a normal car which you could get these for... like a Ford Escort or somthing...
MG
Old September 29th 2004, 15:11
Racelook's Avatar
Racelook Racelook is offline
Talking
Jep Superman they make them (or Gerd Weiser did.. because Franky's and Gerd work often together)..
The one on the picture is one for a 1303.. .. they've another one for 1200/1300/1302.
Grt Wiebrand
B-Extreme B-Tuning.....
