Old January 2nd 2006, 11:46
BugaRu BugaRu is offline
Porsche 915 or G50 in Bugs ?
Anyone gots any Pic's of a Porsche 5 Speed 915 or G50 installed in a Bug?
Fast Cars, & Slow Women makes me drool..
Old January 2nd 2006, 20:02
Im doing a G50 now, lots of cutting. A 915 would be easier but not as effective.
http://www.clubvw.org.au/steve_carter.htm
Old January 2nd 2006, 20:10
trevorbrady's Avatar
see my site for a 915 installed in a 1303 chassis. Centre of torsion tube cut out to facilitate the engine & gearbox being positioned further forward than stock...
http://homepage.eircom.net/~veewrx
Old January 2nd 2006, 21:56
Thanks for the info. Just trying to do my homework to see what I'm getting into before I go there.
You mates are really hacking and a cutting, must be determined to get those Porsche Boxes squeezed in those horns.
Steve you mentioned on your Website that you had to bend your linkage. I saw this used race shifter setup on ebay, maybe if afordable it could help you.
http://cgi.ebay.com/ebaymotors/Porsc...00073892QQrdZ1
Jon
Old January 3rd 2006, 05:12
915 gearbox installed
Hi,
just tried to upload a few pictures of a 915 in a 1303 chassis, but either the files were too big, or the pictures were not worth uploading anymore.
Wanted to show you, that a 915 can be placed in the same position as a bug´s gearbox without cutting the torsion tube out. With my conversion parts (nose cone, traverse front, axle flanges) it´s easy to manage. You can have a look on my site www.bugat5speed.de.
Do also have a 5-speed shifter for the 915 with very short shift ratios. It´s easy to install into bugs and is very exact to shift. Has very strong spring barrier inside against 5th and R-gear.
Can send some pictures by mail to those who give their mail-addresses.
Sorry that I can not show the pictures to all of you. Perhaps you can tell me what I´m doing wrong with my pictures (80 KB is not very much)
Cheers Martin info@bugat5speed.de
Old January 3rd 2006, 08:05
Hi BugaRu
Thats a nice shifter, I think I will stay with the stock one.
I cut my torsion bars for two reasons,
1 Moving weight forward for better distribution.
2 A STI motor with variable cams fitted to a G50 would have put the cam covers out near the rear bumper.
Old January 3rd 2006, 11:42
Does anyone know how much power a Porsche 915 Trans can hold. Also any idea of the R&P and 1-5th gearing?
Matrin... I checked out your Website but couldn't read German. By the way very nice and well done website.
Here is a link to one of my Websites. Nothing fancy, just shows some of my cars. Actually I need to spend some time on it and update it with newer pics and info. The 1966 Bug now has a new power plant.
http://www.bugaru.com/
Steve....
Is the STI engine being pushed backwards because of the added size of the Porsche Trans?
I'm using a STI Block but with SOHC's.. It makes the engine smaller. The pic attached "or should be attached?" This engine is rated at approx 325hp, on 8lbs of boost but I'll know better when I get it on the dyno.
Jon
