88turbo hub swap -to early -big to little disc
can i simply remove the wider hub from my 88 turbo arms
-and fit the hubs from a steel armed 924/44 or a 86? -are they the same thing they look it!! |
The extra track is cast in the ali arms. So the hub's wouldn't make a big difference. If the early hubs are shorter. Then you will have problems with e-brake shoes, and rotors lining up right.
1970 T1 W/MassIVe 2913cc RAT/?EFI? w/direct fire (very soon) and 915 trans 1962 SC 1776cc SP 944NA brakes, 993 wheels VKG |
ya correct
-the steel arm hubs dont work
-good new is that the 86 alloy arm is the same as the 87 alloy arm -the hubs are different -late is wider early is narrower -but does look like the steel armed ones -the splines are different -anyway -the hub shaft is the same 85/6 alloy arm -and 87 - alloy arm -i just done fit the early hub to some late arms, -cos i didn't need the bump stop face !!! |
here
late87 non abs 944 turbo arm
same width as 85 alloy turbo -with bump stop circle -fitted with the 85 hub and the 87 stub axle -fine splines - not bug splines- ylock axle shaft nut -no pin |
and so
the 'majic'
comes from the 1985 only fine splined hub, which looks like the steel armed hub -but isn't -also the 1985 rear disc - if you check the listings, is a one year only affair, although the same diameter, the actual disc thickness is greater |
so
spring plate to wheel face is 220mm
=8 and 3/4 inches - easy get a 225 in then, maybe something bigger on a 53 et 10j?? 255??? -doubt it would fit |
Thread Tools | |
Display Modes | |
