Old July 14th 2006, 13:26
parts for sale -roll up -get your parts here!!
1. 901 fan ring £40
2. pair front iron 944 calipers £50
3. pair of rear iron calipers £50
4. type 4 48mm drla inlets -pair £60
5. 210 flywheel clutch press/plate £90
6. 1,9 wasser long engine £75
7. early 944 spindles/plates £45
8. plates as above -5 sets £10 a pair
9. 1500 4.125 swing axle box £125
10. 4 16 by 6 design 90s with good 205's £275
11. one early 944 front hub £40
12. pair of 4 stud 914 rear disc brake hubs£50
13 pair of 944 turbo 88 - non abs arms hubs discs -wide discs £120
14 1 cb performance drla inlet -offset £20
15 944 turbo split mastercylinder and bottle looks new £65
16 new t25 servo -for above, with a short rod -bug? -£65
17. rear 944 4 pot brembo -been messed with -spacer fitted for 32mm disc £45
18 911 rear discs - i thought they were 944 -not £40
swap for 40mm csp type 4 inlet -40 drlas'32mm vents - 86/87 alloy rear arms-na skinny brakes - 17 inch neg offset wheels - 68 bay beam - monoblock brembo's
