Old November 30th 2002, 13:22
944 Turbo Calipers w/Kerscher Rotors
Alex,
in your 944 disc brake tech article, you speak of using Kerscher Rotors with 944 Turbo Calipers & CB Dropped Spindles for a standard T1 Beetle....I was wondering about doing this on a Super?
According to the CSP adverts, The Kerscher Disc Brake kits can also be used with Super Beetles (you need SB disc brake spindles or a drum adapter), so keeping that in mind then, I should be able to do this conversion using their Kerscher rotors, 944 Turbo Calipers & SB disc spindles.
what do you think?
also has anyone else tried this on a Super?
