Old March 25th 2007, 04:52
are 928 gts and 965 turbo calipers the same thing?
are the 928 gts discs and the 965 discs the same
-are they 330 by 32 -
-do they have a 80mm overall height
-are they a 2 pice bell and disc/rotor - or combined
-i have seen a gts with 17 inch cup 2's
-i have 7 and 9 55et wheels
-if i can indeed fit the 17 inch wheeled cayenne discs
-330 by 32 but 68mm overall height
-will the calipers hit the wheels?
-any one have the small 30mm piston and the clips off the above calipers?
-oh and a dust seal set -oh and 4 long bolts
-just that the cayenned 3.2 discs are 50 quid
-the gts/965 -if they are the same , are 125 quid each
Old March 25th 2007, 04:57
-right, are these a 2 piece set up
-i know i need 80 ish mm, total hat
-330mm by 32mm
-is there a disc available
www.eurocarparts.com
-list the 17 inch wheel discs at 46 pounds plus vat
-are they solid, or drilled - is the hat size 68mm
-or more to the point, where can i get a radially drilled 330 by 28mm discs, combined with a 80ishmm hat
-oh and a 30mm piston, seal set - and the big black clips
Old March 25th 2007, 10:05
http://www.cannell.co.uk/images/944%20Technical.htm
-so no
-911 mount to the front
928 gts to the rear
-ie you could swap them but the clip hinge is wrong
-now stock it says the discs are 322 by 32
911 £107 -drilled
928 gts -£130
v6 cayenne 330 by 32 -hat 68.5 -£46
-so stock 964, would clear a 16 incher -with the hat at 80mm
-i go out a farther 16mm, and come out 12mm
-will i hit a cup 2 et55 -7 by 17
-or do i just stump up for the gts
Old March 25th 2007, 10:06
-so no
928 gts to the rear
911 £107 -drilled
928 gts -£130
its so confusing, 928 gts =is s4 -1993-95 -322/32
