Old January 28th 2008, 00:13
Hoghead Hoghead is offline
caliper upside down?
I am mounting 996 calipers on 944 arms. These calipers have different size pistons and I assume that the small piston is leading. Is this correct?
With the bleeder up, the larger piston is now leading. Is this a big deal, or can the bleeders and balance pipe be swapped?
Old January 28th 2008, 04:51
I can't remember off the top of my head if I swapped the rears or not, check on my website as I have used the same parts as you. If the calipers are the wrong way round you will get tapered wear on your pads & decreased brake efficiency.
Old January 28th 2008, 07:42
I had the same issue. You can mount them so that they are facing the correct way by swapping the bleed nipples over with the fluid cross feed tube, cunning Italians.
Old January 29th 2008, 10:10
I did the same with my 993 rear calipers, as on the 911 the rear calipers are mounted on the front of the rear wheel, while my rear 944T set-up on the bug has the calipers behind the rear wheel...
Be carefull removing the bleeds. Use a socket, not a spanner
Old January 29th 2008, 18:23
On the cross feed tube make sure you use a proper brake line spanner.
Old January 29th 2008, 23:14
I thought that it would be OK to swap the balance and bleed, but thanks for the confirmation.
