Trans mounts: Rubber vs CB rhino
Hi, I'm wondering what would be better for high hp applications, ie subaru turbo. I have high quality rubber mounts installed now from Berg, but if the CB Rhino mounts would be better (stronger, less movement), then I'd swap to those. Any tips?
Thanks Mike
1969 VW Bus 2.2L suby - Driving Daily 1302 EJ20 turbo |
I had CB "Rhinos" and pulled them due to too much vibration and went back to HD rubber mounts...
Kafer_Mike Build 'em fast...or let 'em sit. |
hmm interesting, maybe I'll leave my rubber mounts in and give em a shot then. I also have a tranny strap around the bellhousing and a berg rubber mid-mount. I just don't want the engine to move much because the timing belt cover is pretty close to the body.
Mike
I love my CB rhinos, I run a Mohr mid-mount and a bugpack kafer bar, and I have no issues with wheelhop or vibration. Works great!
1970 Bug 2110cc. ???Whp, ???Ft/Lbs |
Mike
Mike, very little. It certainly doesn't rock like a stocker! When under full tilt, who knows though. If you're that worried about clearance, I'd make more room.
Thanks Alex, ya I might end up removing some material from the timing belt covers, the engine/tranny are as far ahead as they are going to get without doing a whole lot more work. I can't see my engine moving much with the mid-mount and a tranny strap but if it does I'll try the Rhino mounts.
Mike
I use the black, original VW high duty rubbers at the transmission (old style).
Oh, and I drag race it with 270 hp on M&H drag slicks and they don't shear and are quite
