Old March 10th 2012, 10:55
Mr Big Mr Big is offline
What rear brakes can I use on early (steel) 944 A-arms?
As above really? Will the later stuff fit? I want to run vented discs on the back and twin-pot 964 C2 calipers. Will the late 944 hubs work? Will I have to use the 944 driveshafts too?
Thanks guys!
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
Old March 10th 2012, 17:11
I did what you want to do on my sons 1303. The pads are tad wide for 944 rotor surface.
Late 944 hubs are a different animal.
You can use your stock drive shafts if you fit a Beetle stub axle in.
Old March 11th 2012, 12:07
flat flat is offline
As Steve said. You can use 86 944T rear rotor to match the caliper (24mm wide, 3mm spacers required under caliper to center rotor), or Boxster S (2000-2004) caliper (comes cross drilled, no spacing required).
www.vdubengineering.com
Old March 11th 2012, 17:28
Thanks guys! So I just use all the gear straight off the 86 944T? Sounds too easy
Built IRS Box
964 C2 Brembos (Rr)
Old March 26th 2012, 13:19
Ha..its NEVER easy.... but thats part of the fun...
i spent an age tying to get my mota out last night it just wouldnt come out....then after a chat with a mate he says "you did undo the clutch arm on the 915 box didnt you" er no i didnt what a wally did that and the mota fell out...DOH
Old March 29th 2012, 15:59
True. If it was easy it would be finished by now!!
Built IRS Box
964 C2 Brembos (Rr)
