Old September 25th 2008, 19:52
Eatoniashoprat's Avatar
Trans mounts: Rubber vs CB rhino
Hi, I'm wondering what would be better for high hp applications, ie subaru turbo. I have high quality rubber mounts installed now from Berg, but if the CB Rhino mounts would be better (stronger, less movement), then I'd swap to those. Any tips?
Mike
1302 EJ20 turbo
Old September 26th 2008, 22:45
I had CB "Rhinos" and pulled them due to too much vibration and went back to HD rubber mounts...
Kafer_Mike
Old September 27th 2008, 12:15
hmm interesting, maybe I'll leave my rubber mounts in and give em a shot then. I also have a tranny strap around the bellhousing and a berg rubber mid-mount. I just don't want the engine to move much because the timing belt cover is pretty close to the body.
Mike
1302 EJ20 turbo
Old September 27th 2008, 12:53
gonebuggy's Avatar
I love my CB rhinos, I run a Mohr mid-mount and a bugpack kafer bar, and I have no issues with wheelhop or vibration. Works great!
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old September 27th 2008, 13:39
Does the engine move much at idle or under torque?
Mike
1302 EJ20 turbo
Old September 27th 2008, 13:41
gonebuggy's Avatar
Mike, very little. It certainly doesn't rock like a stocker! When under full tilt, who knows though. If you're that worried about clearance, I'd make more room.
1970 Bug
