Old December 3rd 2003, 10:07
944 anti-roll bar
What do you guys use for rear anti-roll bar with 944t aluminium trailing arm?
T4 2666 1303s
Old December 3rd 2003, 10:09
I beleive Alex is using a stock 18mm rear barfrom a 944 for 944T Al arms.
Old December 3rd 2003, 12:09
Any pictures of the setup? Will appreciate greatly. Thanks.
T4 2666 1303s
Old December 3rd 2003, 20:58
boygenius's Avatar
I modified my sway-away anti-roll bar buy cutting the ends up and re-welding them to fit. Here are a few pics.
Old December 4th 2003, 20:38
boygenius's Avatar
Another pic.
Old December 4th 2003, 23:07
63Rag 63Rag is offline
I did it my way
Thats my set up man. When I get to it, Porsche 944 sway bar (have to weld) and I also have aluminium trailers. 91 Carrera C2 brakes too all will go on to a 71 pan with my 63 rag body.
Old December 5th 2003, 15:44
Stuart Stuart is offline
my solution
I've bolted a standard 924 Turbo swaybar (16 mm) to my pan with brackets I bought from kerscher. No welding what so ever just a bold on. Handling is awsome on my 1303 "vert".
Old December 5th 2003, 16:36
vw1303's Avatar
vw1303 vw1303 is offline
can post a picture of the kerscher rear sway bar clamps. I have a 944 bar as well but have no way of mounting it. How much did you pay for the kerscher clamps?
Old December 5th 2003, 16:50
a picture of the clamp. Price I don't know anymore but ask Kerscher.
Old December 7th 2003, 09:12
Went to Kerscher website and in German, but do they just sell the 944 roll bar with the bushings or it comes with the front as a set?
T4 2666 1303s
Old December 7th 2003, 09:17
The brackets are not listed on there website but if you send them a e-mail they will tell you that they sell the brackets without the rollbar. I believe the partnumber is: 7380963 REI
Old December 7th 2003, 09:19
Is bigger the dia the better it is? Performance products have 24mm for 944! I have 22mm bar in front, so what would be a good size for the rear?
T4 2666 1303s
Old December 7th 2003, 14:14
I would say a 16 or 18 mm bar would be good keeping in mind you have a 22mm bar in the front. I don't recommend a thicker one in the rear because this will make a terrible car to handle (over/understeer).
Old December 8th 2003, 21:13
Thanks Stuart. Waiting for Kerscher to reply. Maybe getting the rear roll bar from PartsHeaven.
T4 2666 1303s
Old February 5th 2004, 00:21
boygenius's Avatar
Question.
Can I move the 944 sway bar bushings towards the center of the bar and weld up some little brackets to attach the sway bar to the frame horns. I would make a bracket for the backside of the bushings and weld some spacers under the bracket to space it away from the transmission. Then weld the bracket to the frame horns and then use the stock porsche bushing clamps.
