Old February 12th 2013, 17:20
vw1303's Avatar
vw1303 vw1303 is offline
Tubular Front Control arms for Superbeetle
Finally finished my tubular front control arms for my Superbeetle(1303).
This version allows for 25mm roll centre correction. Made in Chromoly.
Length is adjustable from 0-+50mm wider than stock.
3/4" Chromoly Heim joints at both ends.
Would anyone be interested in a set?
Old February 12th 2013, 19:11
Bug@5speed(US)'s Avatar
VW
Very nice, to be honest I had missed the chromoly bit for the ball joint until today.
Is it just bolted into the rose joint, I.e. threaded from below.
Can u snap or provide more info on ur top mounts for ur struts?
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old February 13th 2013, 10:00
Tim Tim is offline
Hi vw1303,
I am interested in a set as I am restoring/modifying my 1303. I have the 944NA spindles and Golf Mk1 coilover struts. Does the ball joint extender fit the 944 spindle?
Tim
Old February 13th 2013, 12:19
vw1303's Avatar
I'm also running 944 front knuckles. These "ball joint extenders" are 17mm so they will fit your 944 knuckles. I can make them with the standard 15mm as well.
Also you can specificy how much roll centre correction you would like. I tried 50mm but it didn't clear my 15" wheels. Also it seems like some guys are shortening there control arms to help clear big wheels. The overall length of these arms can also be specified in shorter or longer than stock. Another thing is that these arms are 100% bolt on. No modifications necassary.
Old February 13th 2013, 13:44
owdlvr's Avatar
owdlvr owdlvr is offline
I'd be interested in a set. Would even bring your springs back!
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old February 14th 2013, 00:49
cookvw's Avatar
cookvw cookvw is offline
id LOVE a set. how soon can you make them and how much $$?
Old February 14th 2013, 01:57
graham's Avatar
graham graham is offline
I am interested in a set as well price please inc shipping to the UK
gee dub
Old February 14th 2013, 14:17
vw1303's Avatar
Price will be approx. $500CAD. These are made to order: overall length, roll centre correction, and ball joint size can all be specified by the customer. No need to order special ball joints from Germany to run 944 knuckles. This may seem expensive but only slighty more expensive than "new" OEM control arms with bushings and ball joints. These control arms can solve the problem of too much positive camber when running Porsche 944 knuckles.
Please email volksfolks@hotmail.com for any more info.
Old February 15th 2013, 05:47
Tim Tim is offline
Hi,
Any on car pictures?
Tim
Old February 15th 2013, 13:21
vw1303's Avatar
Here is a picture installed on the car.
Old February 15th 2013, 16:45
panic's Avatar
panic panic is offline
Very nice! If I had the dough I would order a set!
Old February 16th 2013, 05:53
Tim Tim is offline
Awesome. I have sent you an email.
Tim
Old February 27th 2013, 16:10
Humble's Avatar
Humble Humble is offline
You have some more mail sir
Old March 2nd 2013, 23:10
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Oops sent you a PM and then saw your email...
Old March 7th 2013, 17:05
Is there a weight advantage?
It would have been extra nice if the ball joint extention would have been excentric so you could dial in extra caster...?
