Old August 9th 2007, 15:50
split_trix split_trix is offline
strengthing rear shock mounts
Has anyone tried to reinforce the lower rear shock mounts on an 944 alloy trailing arm ?
Maybe by welding on support from the bolt back to the arm ? almost like semi boxing the arm....
any ideas
chris
Old August 16th 2007, 14:10
notch11's Avatar
notch11 notch11 is offline
for what purpose? 944's can run rear coilovers no problem, and a 944 is heavier than any type 1 or type 3
Old August 22nd 2007, 07:30
Simon Simon is offline
It will hold, don't be afraid.
Several companies, including KW did very torough testing of the rear coilover setup without torsion bars and all tests passed.
