german look square
here the start of my german look square just spent the last 2 months rebuilding the frame head and replacing alkl the suspension and brake parts just got my rotors and drums redrilled and test fitting my 16' phone dials
still got a long way to go plan on add bug eyes so i can install early 911 lens, irs conversion, and a color change ![]() ![]() ![]() ![]() ![]()
Hi do you plan on lowering? if so pleaze re inforce the bottom mounts on the beam as they are liable to be ripped off if you hit a bump at speed.
If you plan on 4 wheel discs I would suggest a Golf master cylinder its almost a straight fit Armand
IMPI |
Show these folks your wicked GermanLook Fastback
Blitzem with Type 4 power
Hello All
just rounded up most of my parts for stage 2 of my rebuild. 944 alum rear trailing arms 944 spring plates 944T axles and CV's 944 front hubs cross drilled rotors front and rear 944t 4 pot front calipers 911 C4 alum 2 pot caliper that i am going to use on the rear 944 master cylinder 944 rear sway bar and mounting hard ware. So once i start on this i will start posting pic of the progress. I seen lots of info on this kind of set up on supers but very few on typ3's Any input would be nice before i start My biggest question is with the sway bar i got the 14mm rear and plan on getting the sway a way for the front. not sure how much tuning i have to do to get them dialed in just have to wait and see. |
Hi Kombi,
Have you checked the front/rear brake bias? That will depend on the piston sizes in the front and rear calipers and whether you have the later stepped m/c. I would have thought a good starting point would be 944T or 928S4 rear 4 pots to compliment the fronts plus a 19/19 m/c. Also, have a look at what Whiteline suggest for the type 3 in respect of sway bars. Leaving the front standard with the 14mm 944 rear sway bar might induce a little more oversteer than you might be used to. Its not likely to be much but most modern car manufacturers dial in understeer as a safety feature. You might need to add a piggyback bar at the front. Clive |
thanks for your input..... I was thinking about the 4 pot for the rear also but thought it might be a little over kill. the master i have is stepped 23/18 i think
So far i have found no info on the bars whiteline covers bugs only And sway a way has no info to offer. I guess its something i have to play with. the sway a way front bar is 19mm i guess i try the 14mm rear with that. I guess i'll have to try it out and see what works. well I still need to round up a trans and a few other parts before i start the step. Its just going to be nice getting ride of the swing axle to start with |
well right now theirs no sway bars on the car it was a option on early type3 to have them. I'm looking at every possible spec on 1303. the square is a very heavy car compared to a 1303. I'm sure It will get me close If any thing i can get the sway way kit front and rear that might be a safer route and just use the 944 mounts. Well that all optional i guess the main thing is getting rolling on the arms first
And YES At the moment the car is a swing axle the why i doing this conversion to get rid of the swing and go irs. that and i really do not care for the re drilled vw rotors they work for now. But if i going germann look then i might as well do it right. With the master i just get a extra 19/19 So there no problems just to be safe. who knows if i can find another killer deal on rear 4pots it might get them there as well. thanks everyone for all the inputs everything helps |
i going to lower it a little cant get to crazy with it here. the roads are so bad and the speed bumps here are like mountains. I want to put big reds all the way around but i have a lot of other things to do before i get to that point.
I just got to take one thing at a time. thanks for the info. when i rebuilt the frame head i used 1/8 steel should stiffen up the ride alot. ![]() ![]() ![]() ![]()
Oh nice! I'll be keeping an eye on your project, I'd love to see a GL square. There's a special place in my heart for fast wagons
Keep us updated!
finally getting to the end everything is back together greased the front end put it back on the ground. just need to put the tank in and do up so little thing car should be rolling today
12mm spacers i had made ![]() the wheel guides are inner tie rods from my polo classic that i just cut down ![]() ![]()
started doing the front brakes now
hubs machined ![]() ![]() ![]() bearing adapter and sleeve using vw inner and 944 outer ![]() vw race installed ![]() vw inner bearing and 944 outer bearing ![]() test fitting hubs and rotors ![]() test fitting calipers to see what i need to made for a adapter to mount them ![]() ![]() ![]() used the mounting tab off of a set of 944 spindles just welded them to the stock vw spindles ![]() ![]()
