Old November 20th 2003, 18:38
Pillow's Avatar
Pillow Pillow is offline
Urethane IRS pivots
Simple question here I hope.
I am mounting IRS arms (from a 944) and installed the Energy Suspension red urethane bushings for the IRS pivots. Now how do the washers work in this setup?
I assume one on each side, but again unsure.
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 20th 2003, 19:06
Panelfantastic's Avatar
Be sure and post when you figure it out. I've been eyeballin' my bushings and wondering also. Someday, hopefully soon, I will have arms to put them in.
What are you doing for lube against squeaks?
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old November 20th 2003, 20:19
Pillow's Avatar
I am just using the lube that came with them... If they squeek then so be it... Just put on straight cut cam gears and a stinger LOL
Adrian Pillow
Old November 20th 2003, 20:23
boygenius's Avatar
I was told by my local VW shop that the two washers go on the outside of the bushing.
Old November 20th 2003, 21:33
My wife says the stinger on our oval makes it look like it has wood !
VKG Bastage child
Old November 20th 2003, 23:02
craazy Cooter's Avatar
uhhh huh huh he said wood
Old November 20th 2003, 23:27
Pillow's Avatar
>I was told by my local VW shop that the two washers go on the outside of the bushing.<
I have heard that as well... So again I am stumped!
Amazing how simple this question is and I do not really have a clue! Honestly I am beating myself over the head on it... I feel like a novice rub
Adrian Pillow
Old November 20th 2003, 23:40
boygenius's Avatar
I checked my well worn VW beetle manual. It shows one washer on each side of the bushing. I would assume that it would be the same for the porsche suspension. Hope this helps...
Old November 21st 2003, 00:33
why dont you buy a used Porsche 944 manual and see what it say: you should be able to find one on ebay for $5-$30 and have it at your door step in a couple days....at least it would solve the problem
hope this helps
VolkSport Kfer Gruppe
www.VolkSport.net
Old November 21st 2003, 09:13
i've been meaning to look into this same thing myself. just haven't gotten around to it. will look over pelican parts for a parts diagram.
Old November 21st 2003, 12:13
Pillow's Avatar
The answer is... Both!
The Haynes specifies 2 washers on the outside per stock VW IRS.
The Bus Boys instructions state that one washer per side is required for thier special mounts. Which is the way I will go on this.
Do not quote me on this... But I hope to have some control arms in today
Thanks,
Adrian Pillow
Old November 21st 2003, 20:09
boygenius's Avatar
My haynes manual shows one on each side but doesn't even mention them in the text.:silly:
Old November 22nd 2003, 07:53
Deathbug74's Avatar
Deathbug74 Deathbug74 is offline
heh..my ex just complained that the stinger was too loud i think it goes good with the lines of the car...it matches the angle of the new beetle antenna on the roof.
Old January 11th 2004, 17:30
my suspension had been pulled off by the PO, but it had both washers inboard. looks like i am putting them back in with one on each side.
Old January 11th 2004, 19:18
Me too Zen. Haynes or not, this is the way that makes sense.
VKG Bastage child
