Old March 26th 2003, 22:44
beachball6 beachball6 is offline
axle too short
my csp drums came today and the axle is too short to go all the way through the drum. the axle nut gets on about 2 threads thats it. is it ok to cut the drum part that is too long it doesnt look like it will hurt the integrety. wat should i do?
shawn
2332cc 65 looker
68 stock auto stick
i think i can beat your honda maybe...
Old March 29th 2003, 01:10
kdanie kdanie is offline
Sounds like you have drums for a '68 that uses a slightly longer axle and wider shoes. Having that part machined down some is common but I don't know for sure how much you can take off.
ken
Old March 29th 2003, 19:34
flat flat is offline
68 and later cars have longer splines. To use the 68+ drums on earlier cars, you have to trim 0.600" - 0.625 off the snout of the drum. Good Luck
www.vdubengineering.com
Old March 30th 2003, 17:31
thanx for the exact measurments
shawn
2332cc 65 looker
68 stock auto stick
