Old April 29th 2003, 04:01
BigPhattyVW's Avatar
BigPhattyVW BigPhattyVW is offline
Engine Spacer question
Hello
If I were to put a 82mm crank in with 94mm B Mahle/Cima Pistons and 5.5in rods, would I need cylinder spacers? If so what should i do, lower the crank size or shorten the rods? I'm asking this because the exhaust that I want to use isnt made for wider than stock engines.
Clint
Coming Soon!
86mm X 90.5mm German Look Bad *** VW
Hopefully Soon!!
Back home in Port Orchard, and saving for the Bug
Old April 29th 2003, 11:08
kdanie kdanie is offline
I would buy a different exhaust, it's cheaper than a different crank or rods. Going with shorter rods will increase the side loading on your pistons, increasing wear. Shorter stroke will cost you torque. Your choice, it's all comprmise.
ken
Old April 29th 2003, 12:32
hot66's Avatar
hot66 hot66 is offline
i'm in the process of building a 82x94mm type1 with 5.5 rods & stroker pistons. I am expecting it to be very close to stock in overall width.
project in progress
Old April 29th 2003, 16:26
Allright!
Hello
Thanks Hot66 for your reply! And when you do finish your engine please inform me if you needed to use any spacers! Hopefully not because I wanted to put that turbo kit on but the exhaust isn't adjustable. Oh well
Clint
Coming Soon!
Hopefully Soon!!
