Old October 8th 2002, 19:04
darren's Avatar
darren darren is offline
18" Porsche cup 1's ???
Like it says on the tin
are Porsche cup 1's available in 18"??
Anyone know ??
darren
Old October 9th 2002, 03:31
hot66's Avatar
hot66 hot66 is offline
as posted on vzi
http://wheelenhancement.com/Style.htm
split rim types only i think, which means big money ££££££
project in progress
Old October 9th 2002, 16:54
darren's Avatar
Exclamation
Cheers Jim
Split rims also means pig ugly
It was just a thought.
How are you doing with my car by the way?
Is it nearly finished?
darren
Old October 9th 2002, 17:36
hot66's Avatar
nearly finished? thats a joke yes?
You should know by now, things don't tend to happen too fast
Mind you, finally got my new garage doors, almost finished painting the garage floor, & then the cab is coming out of storage & work begins again
project in progress
Old October 12th 2002, 13:28
Jim Andritsakos's Avatar
Hello guys!
Well, if the question is if Porsche was produce 18" Cup I wheels the answer is NO.That you see around available are made in Italy replicas.
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old October 13th 2002, 19:44
darren's Avatar
Jim
that IS the question I am asking.
Is an 18" replica availible?
The only replicas in that size i have found are cup2 or turbo type.
I would like Cup 1 in 18".
darren.
hot 66 i might have bought an engine! and mine is complete not in boxes!
I should know tomorrow if its mine or not
Old October 14th 2002, 02:34
hot66's Avatar
at this rate your cabrio is gonig to be finished before mine
I should have my new wheels this week though
genuine cup2's 17x7 et55
Are you gong to tell us the plans for your cabrio are are are they still the same?
project in progress
Old October 14th 2002, 08:05
darren's Avatar
Finished? My cabrio
I never seen anything that was less finished!
Lots of plans, but they are always changing
68 cabrio
Kerscher brake kit vented front and solid rear.
17 or 18 (if I can find any) rims.
2 sets of day moulding wings front and rear different year so i can change how it looks from time to time
Memo imports front and rear lights for above wings
custom lights for the other set of wings, still looking these
W lid, with louvres :silly: punched in or vents if i can find some to weld in
Long bonnet
dechromed, no bumpers.
red9 front coilover type setup.
T1 engine size?? Porsche style cooling
(Hot 66 let me know how you get on with your shroud)
Colour still to be decided.
Thats enough cats of bags for now
darren
Anyone know whats going on with volkszone and total forums???
I cant ge on either?
Old October 14th 2002, 08:44
Hello Darren,
Well, they are avaialble in 18"...
www.milemiglia.co.uk
Rgds,
Jim
Jim Andritsakos
89 T3 Syncro panel
Old October 14th 2002, 09:26
darren's Avatar
Originally posted by Jim Andritsakos
Hello Darren,
Rgds,
Jim
Hi Jim
I had a look on there, they make the CUP 1 in 17 only 7Jx16H2 7½Jx17H2 9Jx17H2
darren
Old October 14th 2002, 15:52
Hello Darren!
Well they are available in 8.5 ans 9.5 x 18.
I send you the wrong address!
Here is the correct
http://www.performancewheelsupplies....rsche/main.htm
Rgds,
Jim Andritsakos
89 T3 Syncro panel
Old October 14th 2002, 18:11
darren's Avatar
Smile
Cheers Jim!
Old October 14th 2002, 18:16
hot66's Avatar
darren - did you buy the VSM motor?
project in progress
Old October 14th 2002, 18:24
darren's Avatar
Nope some else from VZI had it.
it was 2007 with 78.4 cast scat crank and 90.5 B+Ps
Paul said he could sort out another one and get Laurie Petit to build it.
What do you think about cast cranks? From what i've read best to steer clear of them?
darren
Old October 14th 2002, 18:28
hot66's Avatar
cast cranks....comes down to wether your motor is designed to be a low reving torquey one, if this is the case then the cast crank will be OK. If your building a high revving screamer then I think you might be asking too much of a cast crank & worth spending that bit more for a one piece forging
project in progress
