Old September 15th 2005, 19:12
bow's Avatar
bow bow is offline
carbs
what kind of dual carbs can i run on a budget im thinking of dual kads
Old September 15th 2005, 23:40
Depends on your engine combo and budget. Kadrons and Weber 40IDF are more than adequate for a smaller displacement driver and can be found at reasonable prices.
Kafer_Mike
Old September 16th 2005, 08:24
bow's Avatar
bow bow is offline
it is a pretty good engine 94 pistions 044 race heads fk-8 can 72mm crank all that power and no way to make it go
Old September 16th 2005, 15:47
A set of reworked Kads from AJ Simms will work, thoughy you would be further ahead with dual 44IDFs, 48IDFs/IDAs or 45 Dells. Add at least and 1 5/8" header (no boxes) to improve the flow and it should move plenty...
Kafer_Mike
Old September 16th 2005, 16:49
bow's Avatar
bow bow is offline
ok that is what i was thinking
Old October 19th 2005, 18:31
javajuice javajuice is offline
i think 1 5/8" is too much, better 1 1/2"
