Old June 22nd 2006, 03:50
Not Just My Tag...
So its true, this GL obsession keeps me up. It's 12:48am on a work night!!! So what does a hardcore GLer do? I bought me some personalized plates!
Look for UBR DUB on the highways next year!!!
Old July 6th 2006, 18:31
speedy's Avatar
speedy speedy is offline
nice, lol so will the bug be on the road for next year , i am in usa and canada for 4 months next year and would not mind seeing it in real time
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old July 6th 2006, 19:41
you are a sick man Jason.
Old July 6th 2006, 20:35
cheers jon
You're welcome any time. I've got an extra bedroom and they say Sonoma County is a good place to go to, that is if you like wine and beautiful scenery...and Infineon Raceway... and redwoods.... and San Fran is about an hour south, so yeah, I think you might enjoy the stray up this way.
Old July 6th 2006, 23:37
MikeVW's Avatar
MikeVW MikeVW is offline
Jason,
What is still on the "to do" list on the bug? You said the shift linkage is a little stiff from side to side since you are using a Boxter shifter. I am putting a Honda Prelude motor and trans in the back of mine and I think the stock shifter will shift okay with the lines running straight back to the trans. unless my minds eye is way off. I forgot to thank you for the part numbers on the bushings for the control arms!
Mike
Jack of all trades and master of none!
http://www.Type1R.com
Old July 7th 2006, 18:33
Originally Posted by MikeVW
Jason,
Mike
The "short" to-do list reads as follows:
Install calipers and rotors from Lanner then plumb and bleed brake lines.
plumb fuel lines using MkIV VW quick connect ends
Install 034 EFI including cooing fan control
Re-install shift linkage and monkey with it.
Start it up!
Spend the next 5 years sorting out all the kinks.
The problem with the linkage is that it's backwards, so unless you've figured that out, it's kinda a pain. That's why I used a Boxter shifter, because the cables exit out towards the back.
Old July 8th 2006, 12:58
chug_A_bug's Avatar
hey hey ya dude I'm up alll night just thinking looking and breathing GL's
Old October 5th 2006, 08:45
ajsyrup ajsyrup is offline
maybee i am a little special little more info on these??? sounds interesting
