Old January 4th 2008, 10:40
Veedub Veedub is offline
will these fit ....final time i hope
stock drums redrillied for 5-130 and phoe dials with the 23.3mm et 15x7inch.Will they fit inside the stock fenders?Also what size et would i need for the front and would i need to narrow the front at all.
thanks guys you guys help me out alot.
Old January 5th 2008, 01:59
Would the 15x6's with the high offset be a better option for a Standard 72 bug with IRS, stock fenders,drums with the 5-130 bolt pattern and eventually lowered some?
Old January 5th 2008, 09:00
On my old daily driver I used 6x15 ET 36 Cookies on the front and on the rear 7x15 ET 23 Cookies. This was a standard type bug with a beam front end. They fitted fine.
Old January 6th 2008, 01:00
Cool so since the 15x7 cookies with a 23et fit nice under the rear then the phones with the 15x6 and 7 width will fit with the same offset?
What bout the Phones with the high offset but 6" wide, will they fit w/o spacers?
Steve on the front of your bug, was the front beam narrowed at all?
Old January 6th 2008, 02:03
I'm not sure what offset the 6 inch high offset wheels are. The front beam was stock apart from lowering on that car.
Old January 6th 2008, 11:08
The 6" Phones come 23.3et or 53et.Since the Cookies are 23et as a 7" wide, does that mean they'll fit nicely inside the fenders and possibbly I wont need to narrow the frontend then. If so thats what I want.
Thanks Steve C
Old January 6th 2008, 19:39
The 6" Phones with a 53et will sit 30 mm closer to your inner fender than the 23 et ones.
Old January 6th 2008, 22:35
IM kinda confused with these offset things.OK, the 53mm 15x6's wont stick out but I'll need spacers right?THe ones with the 23mm offset they will stick out then?
Old January 10th 2008, 01:18
Oy I have bad luck on Ebay I always lose!!!
Anyways I have decided to wait it out till my bugs street worthy which will be soon very soon
Im gonna go a different route, either Axis Oldskool rims
http://www.streetdreams.org/wheels/r...ack%20Machined
there 15x8 with a 25mm et, I played with this site
http://www.wheelsmaster.com/rt_specs.jsp
comparing them to the stock 15x4.5" rims with the 34et, these wheels will be 100% clear (leaves even more room than OEM) and will stick out 14 mm (0.6'') farther which I dont think will be a problem, just maybe narrow the frontend maybe 4"
Then the other ones IM thinking od are 15x7 Axis OG San with a 35et
http://www.streetdreams.org/wheels/r...d%2520Lip/15/7
and according to the tire/wheel site the clearancing will clear in the suspension and fenders.Both weigh 14lbs each which is a plus.I'd just buy the 4-100 drums from cip1 and run the drums for a little while.
Which you guys think will look better on a bug thats baby blue with the stock offwhite fenders?
Old January 11th 2008, 01:17
Well I just found out that the stock vw wheel offsets for the 4.5" is actually 46mm et.So can someone tell me please if this is a good thing.I know the 4.5's sit inside the fenders pretty deep under there, so if I got a 15x7" rim for front and rear with a 35et offset I should be find according to that site in the previuos post.Says I'd be 100% clear of the suspension parts, and the package will stick out 11mm (0.4") farther.
Now with the 15x8's with the 25mm et, it says the suspension will be clear and stick out 26mm (1") farther to the fenders.
My question now is would the frontend need to be narrowed then?
Old January 23rd 2008, 00:36
DRUM ROLL PLEASE.....
I finally decided IM going to get a set of Axis rims....they are 15x7 with a 38et and 15x8 with a -27et (will require 3" wider fenders)
