View Poll Results: which front shocks?
koni reds 8 53.33%
spax 1 6.67%
bilsteins 5 33.33%
others 1 6.67%
Voters: 15. You may not vote on this poll
Old July 11th 2003, 04:12
hot66's Avatar
hot66 hot66 is offline
front shocks - koni's, spax or bilsteins?
thinking about buying some front shocks to suit a beam front suspension, slightly lowered & dropped spindles.
koni's
spax
bilsteins
project in progress
Old July 11th 2003, 04:26
lightning bug's Avatar
I voted Koni b/c I've had good luck with them. Bilsteins adjust themselves though and are bombproof. Either one, you'll be fine. Spax... Yuk.
Julian
'74 Super
Old July 11th 2003, 15:38
MattKab's Avatar
MattKab MattKab is offline
Lightbulb Others
http://www.koni-na.com/cars.html
Old July 11th 2003, 17:07
hot66's Avatar
matt, you running Koni reds then? I'm very interested in peoples opinions of the shocks they are using
project in progress
Old July 11th 2003, 22:43
Alex's Avatar
Alex Alex is offline
I voted Koni. The Bilsteins are as good or even better shocks....but they have a problem:
They actually push up the car and it will not look as low anymore.
When you compress a Bilstein the shock comes back up. The Koni does not.
So when the car is not moving you will find that it is not as low as when you are driving. My friend had the problem in the 90s with his fronts and I had the same problem with my New Beetle.
Old July 12th 2003, 05:05
petevw's Avatar
petevw petevw is offline
how about KYB's?
'72 super
'65 bus
'52 split
Old July 12th 2003, 09:19
MattKab's Avatar
Yellows mate, front and back. 'Can't fault them, except tweaking the front is a bit of a ball-ache.
This video clip is good:
http://www.koni-na.com/images/int_subbutshockvidov.gif
Matt
Old July 14th 2003, 11:03
hot66's Avatar
koni reds it is then
project in progress
Old July 16th 2003, 21:05
i need to make this same call soon. where are you buying hot66?
Old July 17th 2003, 18:04
hot66's Avatar
prob a place in the UK near manchester, can't remember the name though
project in progress
