Old August 28th 2007, 15:40
notch11's Avatar
notch11 notch11 is offline
I have also done something similar.....on the front of a type 3, i used the front discs with 5x100 bolt pattern then machined off the brakesurface so they would fit in a rotor from a 2001 jetta 2.0 then fabbed up brackets and used a caliper from a 96 jetta 2.0 and voila........bigger brakes w/floating calipers using al stock vw parts! (except for the custom bracket) http://www.franklinsvwwerks.com/phpb...760&highlight=
Old September 4th 2007, 08:58
mabbo mabbo is offline
hey guys,
would this work?
if i used a stock vw 4 stud disk or drum machined down to use as a hub with a porker vented disk, then have the 4 stud vw pattern put into the disks. a early 944 caliper and mounting bracket.
i want to keep 15" vw pattern wheels...
cheers
mabbo
Old September 4th 2007, 12:53
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Hey Mabbo,
I've got a set of early single-piston sliding calipers if you're interested.
Old September 5th 2007, 11:27
hey dorigtt
i guess the postage from america would be a fortune, im in the uk so would probrally be easier/cheaper to get some from over here...
cheers for the offer though.
mabbo
Old September 7th 2007, 21:16
DORIGTT's Avatar
Naw! Postage is nearly free... I'll just scan them and email them over to you
Old November 28th 2007, 08:43
Dave Dave is offline
Originally Posted by DORIGTT View Post
I recall a thread where someone machined down the drums (with 5x130 pattern) to fit inside or on top of a Porsche rotor to be used as a hub. What's the feasibility of this?
Is this the one you're on about? My mate did it to his Baja and it works a treat. The vehicle gets some hammer too and it seems to be holding up well.
http://www.airsouls.com/how-tos/rear_discs.htm
Somehow still vertical....
Old December 12th 2007, 09:22
Originally Posted by mabbo View Post
hey guys,
would this work?
cheers
mabbo
can anyone see why this wouldnt work?
vw 4 stud drum or disk machined down to use as a hub
get a 944 disk re-drilled to 4 stud vw pattern
bolt the 944 disk up to the back of the "hub" like Steve C's method
regular 944 mounting bracket and single slider caliper
this should give me vented disks and still use vw 4 stud wheels?
mabbo
Old January 31st 2008, 20:43
dub_crazee's Avatar
You could use stock 4 stud drums instead of discs and do the same thing, the disc will give a slight track increase of the drum. If you then studded the brake drum to 5x130 that would work.
On my old 1302 I used 5x130 bug discs with the braking surface removed, then bolted the Porsche rotor on the back with a spacer to get the offset correct in the same manner that Porsche rotors fit up.
Steve your set up looks nice
can i ask - are the studs fitted to the hub, or to the disc, then go through the hub?
And what studs did you use?
Dean
Old February 1st 2008, 00:01
If you look closely at the top photo you can see the outer piece is a stock beetle disc with its braking surface removed, then you can see a thin aluminium spacer between the cut-down stock beetle disc and the Porsche rotor.
So to answer your question, I just used high tensile studs screwed into the threads in the cut-down stock beetle disc with a dab of Loctite to hold them in.
PS, there is a seller on Ebay Australia who sells these high tensile studs called "vforceracing".
Old February 1st 2008, 06:47
dub_crazee's Avatar
thanks for that info - so the wheel studs are just put into the old beetle disc - awesome. you have been very helpful - thanks. oh 1 more question - which disc would you suggest is best to use as ive noticed they come in different heights!
Old February 1st 2008, 07:57
No worries. Those discs are from an early 911, they also fit 944 (1982 - 1989), 911 (1969 - 1983) E,T,S,SC & Turbo.
You can download a brake rotor catalogue from here www.dba.com.au It has all sizes and heights listed
Old February 6th 2008, 16:01
fuzzybear1981 fuzzybear1981 is offline
dont suppose anyone has the dimensions you need to machine the beetle disc to get the same as the 944 T hub?? and when i have it machined what i needto shim out by?? Cheers anyone
Old April 1st 2008, 15:58
smithe68
Interested in that info too.
Old April 7th 2008, 16:39
bushoarder bushoarder is offline
i have been working on a conversion fitting 944 late discs to bug hubs and am keeping 4 stud bug pattern. you need to fit a spacer between the hub and the inside of the 944 disc depending on your application ~5mm.
i had a bloke i know machine 4/130 into the porsche disc - fits ok and you only end up with 1 hole with a thin land ~5mm. i made press fit spacers to the hubs which align the disc concentrically ensureing no issues.
haven't finished the caliper bracket yet......
using ibiza cupra calipers on mine 54mm pistons.
