Old June 8th 2007, 06:26
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Machining drums to be used as hubs?
I recall a thread where someone machined down the drums (with 5x130 pattern) to fit inside or on top of a Porsche rotor to be used as a hub. What's the feasibility of this?
Old June 8th 2007, 11:33
Better bet would be to machine down aftermarket Porsche pattern discs, they have the strength in thickness then and you could fit studs.
Old June 8th 2007, 12:53
DORIGTT's Avatar
When you say Porsche discs, are you referring to VW disc brakes with the Porsche pattern? And are they available for the rear that way?
Old June 9th 2007, 05:22
Yes, I was talking about Porsche 'bolt pattern' discs for a VW, they are thicker around the mounting area. Porsche made the rear hubs already (they are on the 944 )
Old June 9th 2007, 07:43
DORIGTT's Avatar
Thanks ricola,
One of my goals is to keep possible width increases to a minimum... Ghia you know. My figurations are / were that I would only (possibly) get <10mm increase per side which would be a good thing for those of us who are a little lacking in wheel well space... Ghia you know Anyway, I figured that would be a good way to not widen things too much.
I've got some early 944 aluminum trailing arms with all the necessary components to mount them on my Ghia, as well as the front hub that needs to me modded to work (later style for the front hub), I've just got doubts about the 'relative ease' of making it all work... Ghia you know
DORIGTT
Old June 9th 2007, 08:28
You could use stock 4 stud drums instead of discs and do the same thing, the disc will give a slight track increase of the drum. If you then studded the brake drum to 5x130 that would work.
On my old 1302 I used 5x130 bug discs with the braking surface removed, then bolted the Porsche rotor on the back with a spacer to get the offset correct in the same manner that Porsche rotors fit up.
Old June 9th 2007, 11:11
DORIGTT's Avatar
How well did that method work for you?
Old June 10th 2007, 10:22
They worked fine, I will be using them on my next car as well.
Old June 10th 2007, 11:01
DORIGTT's Avatar
Cool, thanks.
Old June 12th 2007, 14:13
GS guy GS guy is offline
Why not just go with the CB chromoly hubs? (from their race strength disc brake kit)
BTDT on machining down some drums. That cast iron is hard material, requires carbide tooling. A lot of work involved, you have to make a good fitting mandrel to hold-em while machining, lots of cutting and machining time, etc. If you were paying someone to do the work you'd likely be much $$ ahead getting the CB hubs.
Jeff
Old June 12th 2007, 16:19
DORIGTT's Avatar
I just looked at their website per your suggestion and didn't see any front hubs as you mentioned.
Old June 12th 2007, 16:31
Oops, didn't seen any specific references to front hubs.
I was referring to the rear CB hubs.
I think the only aftermarket front VW hubs I've seen are Vdub Engineering and Airkewld.
Old June 12th 2007, 19:05
DORIGTT's Avatar
O' Tay I got it now
Old June 21st 2007, 11:39
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
Steve ,your a genious .I reckon i am going to nick your idea for the back of my bug as the 944 rears are way to widefor my 66, but reckon i can use either the carriers or a beetle drum to keep the stock offset.sorry to crash your thread Dorigtt
Old June 21st 2007, 18:40
Hi Skeeter
You could use Type 3 rear drum centres for that, or buy some 5x130 rear drums or another thing I looked at was cutting the back of the steel arm 944 flange down to narrow the track, you would end up with less spline area, I'm not sure how that would go with high horse power.
