Old June 8th 2009, 03:28
Tnx Steve, Scott!
Originally Posted by Scotts73SB View Post
. that blue one with the black wheels is sure mean lookin too!
It sure went like stink too. Its pretty light and with the 103x71, 44IDF engine it was right on my tail for quite some time. Pity his fuel pump cavitated or s/th as it would not pump fuel after a few laps.
Quite a few people at the track were amazed how fast our bugs went. Priceless
Old June 8th 2009, 04:23
chug_A_bug's Avatar
And that's why, I bet 90 % of us build these kinda cars...
I know I do
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old June 8th 2009, 20:13
Humble's Avatar
Humble Humble is offline
Lookin' good! We need more in car footage I love racing in a beetle for the fact that people don't expect it to be quick. I've picked up a couple of stickers for the back of my track car that play on that idea. The first says "Never get stuck behind a vw" and the second says "Pass me with a smile"
Old June 9th 2009, 06:53
evilC's Avatar
evilC evilC is offline
You lot haven't been watching Herbie films over the last three decades then???????????!!!!!!!!!!!!!!
Old June 9th 2009, 12:58
Humble's Avatar
That's hollywood, I want the real mccoy!
Old June 9th 2009, 14:48
evilC's Avatar
Personally, I prefer the Wacky Racers. I see myself as a Dick Dastardly (or was it Muttley ??)
Old June 14th 2009, 12:14
michael86 michael86 is offline
Hey Wally I found ya!
Going to follow the progress from here.
Michael(aka as Tikimadness)
Old June 17th 2009, 16:10
Made a printscreen of a testrun with an aim at 1.0 bar through the range.
Its not perfect yet, but it does show that I now have 'full' boost at 3400 rpm
The run was made in 4th gear from 2300 rpm onwards to just over 6k rpm (= appr.120 mph...), still tuning for fuel as this was the first time with an entirely new fuel map a bit changed timing and EBC map as well:
As you can see, air intake temps are a bit higher than last time as well. Temps rose to 37C after a few WOT runs.
Old June 17th 2009, 19:20
Humble's Avatar
Looking pretty clean! Your air temps are a lot cooler than mine since I'm not running water injection at the moment. My temps hit 70-76C at 10psi and I'm totally jealous over full boost at 3400. Mine barely starts spooling by 3500, no low end for me. Does the software allow you to change graphs like AFR instead of lambda? What's your "water temp" actually measuring?
Old June 18th 2009, 01:47
Yeah, I could reverse lambda an present AFR. Watertemperature is actually the oil temp on the bottom of the head. I only use it for warm-up and it shows usually a little hotter than the temp under in the sump, which I read with a seperate sensor and a gauge (VDO).
I only use a mercedes transmission cooler in the nose and even on the track (high rpm constantly), oil temp didn't rose over 90C, which even surprised me.
Tuning is everything
Old June 21st 2009, 14:00
At our big national meeting today at Budel I went on the very same mobile rolling road dyno as a month ago and I tuned again for the same 14.7 psi or 1.0 bar boost:
Complete with a bit of flames from the exhaust...:
http://www.youtube.com/watch?v=T0PDByAqyjM
Thanks for the video Tiki!
Print-out above shows 288 hp at only 5561 rpm and 377 Nm (278 lbs.ft) at 4007 rpm corrected for transmission losses.
At the rear wheel print-out it shows I have 266 RWhp at 6177 rpm which sounds like a more credible rpm.
I need to look at that dip at 4500 rpm, but it may be intentionally as I withdrew some extra timing at what I thought to be the optimum torque point.
Anyhow, the tranny obviously looses very little hp, which is nice to know as well I suppose.
Very happy with the 20 RWHP addition I got with some optimization of some parts and a bit of extra tuning
We also had a little drag race today at our local meeting over about 175 meters, which was fun to do as well. Everything stayed in one piece, sun was shining, so all in all I had a fantastic day
Old June 22nd 2009, 16:09
skywalker
@ Budel:
Old June 22nd 2009, 16:12
kuleinc's Avatar
kuleinc kuleinc is offline
wicked pic...
Everyone told me its not a good idea to daily drive an aircooled bug. I agree, if the engine has a distributor and you use cheap engine parts... OR you have an early car without the decklid vents or you neglect to add an oil cooler with fan...
Old June 22nd 2009, 16:33
Tnx for the nice pic Luuk!
I hope to find some vid's of the drag-race finals as I managed quite a nice burn-out with that run if I say so myself
Old June 23rd 2009, 05:39
evilC's Avatar
Excuse my ignorance, but what is a NAG? What does the acronym stand for?
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
