Old February 8th 2011, 06:11
No seperate and/or additional gravity feeding if thats what you mean.
Return line from regulator still goes back directly into the fuel tank close to wwhere the feed pump picks up the fuel from the tank.
Upper connection on catch can goes back to tank as overflow and also acts as a breather.
Pics of the set-up are on page 33: http://www.germanlook.net/forums/sho...t=9953&page=33
The idea of mine is/was that a zero-pressure feed pump (which is now the 944 pump) always supplies more fuel then the high pressure pump will be able to flow at 45 or 60 psi.
Old February 8th 2011, 08:06
Hi Wally
The reason that I asked what sort of pump you were using to feed the surge tank / swirl pot is that myself and a friend both had noise and heat issues when using EFI type pumps to fill the surge tank / swirl pot.
My friends pump actually failed. We put it down to cavitation in the pump as it was not restricted with a pressure regulator etc as it would usually be in a EFI set up.
We are both using Carter lift pumps now.
Obviously your car has travelled many kilometres using a pump this way, but it maybe something to consider.
Old February 8th 2011, 08:47
Thanks for the info Steve! I would feel better having a dedicated large-volume, low-psi feed pump for this tbh.
I never could find anything for this.
Hmm, worth looking into Carter pumps (never heard of them before).
Old February 8th 2011, 13:29
Originally Posted by Xellex View Post
are you sure that inlet from the tank wasn't in fact a return -outlet- back to the tank from the catch can?
That could be I didn't see where the lines went to
Old February 8th 2011, 15:51
Why/how could that be the problem if the electric pump clearly was broke and it restarted fine with a new pump?
The lines run as intended btw
Old February 8th 2011, 17:37
Steve Arndt Steve Arndt is offline
More header pics at the import site. They are WRX this time so a bit more relevent. Divided housing, but incorrect cylinder pairing
http://www.honda-tech.com/showthread...599745&page=18
Steve Arndt
Old February 8th 2011, 17:57
Why would you say incorrect cylinder pairing? Opposing cylinders are paired, which is correct, also on a subaru.
He just did not kept the single wastegate divided, which he should and that is indeed a BIG mistake. Might as well kept it simple and 4 int 1 then.
Old February 8th 2011, 18:00
Xellex's Avatar
Xellex Xellex is offline
Hehe, there's been a misunderstanding, I was reffering to 70Turbobug's post about seeing a race car with 2 separate inlets from the tank to the catch can, and it has nothing to do with your electrical pump problem :P
www.vw1303s.com
Old February 8th 2011, 18:05
Ah, mystery solved ;-)
Old February 9th 2011, 14:47
Right you are. I was viewing on a small netbook screen.
Steve Arndt
Old February 9th 2011, 15:25
Eatoniashoprat's Avatar
Wally,
http://www.summitracing.com/parts/CRT-P4600HP/
This is the one I have been using to feed my surge tank. It seems to work well and haven't had any issues yet. I had some noise from it but it was caused but not mounting it properly and the body of the pump was touching some steel, giving off some vibration.
I also have a small bleed line of 3/16" coming from my surge tank and tees into the return line. This ensures that I do not build up pressure in the surge tank.
Mike
1302 EJ20 turbo
Old February 9th 2011, 15:44
Originally Posted by Eatoniashoprat View Post
Wally,
Mike
I searched and noticed that one too. It flows 100 gallons per hour, which is 450 ltr/h (?) which is quite a lot: a 044 pumps 300 ltr/h at 3 bar fuel press. and 250 at 4 bar I believe. That means a lot of by-pass. I think the other Carter pumps with 72 gallon/h rate (325 ltr/h?) would still provide more then the 044, but not have as much by-pass.
Too much pump in general would not be a problem however
Tnx.
Old February 10th 2011, 12:41
Tnx.
That was my thought about too much is OK. After having fuel supply issues in another car, and not having baffles in my tank I thought I'd just put something in that even if the pick-up gets uncovered momentarily there is NO WAY my high pressure pump will lose supply. My hi-pres is a WALBRO but will be a 044 sooner than later. (walbro is LOUD).
Mike
1302 EJ20 turbo
Old February 22nd 2011, 18:41
You're probably right Mike, so I 'won' me a 100 gph one from evilbay. Hope it gets here soon.
In the meantime, I figured this turbo needs a bit smaller A/R for this little engine and it came in today: 0.91 instead of 1.00 A/R: Just looks as big as the other one
Old February 23rd 2011, 01:21
MX67 MX67 is offline
Downsizing is cool these days
1967 Bug
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests)
