Old March 15th 2011, 16:07
bushoarder bushoarder is offline
1303 German Look Wannabe
I've been reading on here for years and thought i'd post a link to my resto - on VZI..
http://www.volkszone.com/VZi/showthread.php?t=514502
some taster pics! I've pretty much finished the body now -couple of cosmetic bits to weld up before I can commence modifications
Porsche 901 gearbox loosely fitted whilst awaiting my NOS 1800 Type 4 motor. I'm planning on injection and have several T4 injection systems along with a knackered turbo i'm going to use for pipework mock up!!
Hoping to get the chassis rust repaired shortly - there isn't much to do - then maybe I can get the new suspension and brakes started.
Building a 74 GL 03 take a look: http://www.volkszone.com/VZi/showthread.php?t=514502
Old March 16th 2011, 03:13
oasis's Avatar
oasis oasis is offline
Yikes! You're taking on some tough duties. Obviously, you have some mad skills. Well done so far. Performance will be the easy part.
(2004-2008): 1971 1302 w/2056
Old March 16th 2011, 20:39
You are off to a very good start so far! Keep the updates coming!
Old March 16th 2011, 23:23
WOW. Thats a lot of cutting, fitting and welding.
Old March 17th 2011, 16:55
Thought i'd show some of the earlier pics!
Here are some of the earlier pics showing some of the work i've had to do:
Old March 17th 2011, 17:00
Particularly proud of this handmade panel!
Old March 17th 2011, 19:54
Just a taster!!!
Old March 17th 2011, 20:45
That is alot of metal repair!
I've got to do some of that to the lower corners on rear window... not looking forward to it. You're doing a graet job! Keep it up!
Old March 17th 2011, 20:56
Jayzus!!! You wouldn't by chance work at a dairy that makes swiss cheese wud ya? Nice work patching her up!
Old March 20th 2011, 15:41
Repaired the floor pan rear brace
I measured this up at 2mm, then looked at a bit I had left over from a previous floor pan I had fitted - generally have never used this part - and found it to be 1mm thick!!
So moral is don't use this bit off pattern pans!! I made a piece up in the end from 2mm sheet.
So all repaired and awaiting the pan repair that I've made but not fitted
Old March 20th 2011, 19:31
Oldskool1303's Avatar
Oldskool1303 Oldskool1303 is offline
Wow!! nice metal work
Old March 25th 2011, 04:49
Well done on the rust repair! Its such a accomplishment if the body is solid again as in your first pics.
I know exactly what it takes as you may have seen in my thread on the first page ;-)
Keep the pace and get her painted and driving asap since that gives extra motivation, then you can upgrade later as much as you like :-)
Old March 26th 2011, 15:05
Hi Wally,
Thanks, i've looked intently at your work and it is an inspiration to me for my bug! If mine turns out half as good as yours I will be very happy
I have a turbo on the bench lol!!
Old April 2nd 2011, 14:39
Not much to report.... maybe get more done next weekend.
Old April 6th 2011, 16:16
The Plan....
Hi All,
Here is my latest thoughts on the bug...
ATS rims for that classic German Look motor
Opinions invited.....
