Old October 10th 2012, 13:34
petevw's Avatar
petevw petevw is offline
Hey guys, it's been awhile.
Got sidetracked from this '52 project with my bus. Now that it's 95% done, time to get back on the splitty!
http://www.kustomcoachwerks.com/foru...pic.php?t=5426
Engine look familiar Dave(NO_H2O)?
Out of the smack black bug and into this.
'72 super
'65 bus
'52 split
Old October 10th 2012, 14:53
Good to see the old 2275 is serving you well. It had a good torque cure that should do well in the bus. We missed you here but I knew you would be into the bus for a while as soon as I saw pix of it. Nice find and nice build to bring it back and update it. Love that bus.
Old December 12th 2012, 18:50
petevw's Avatar
Looky here: 2332T for this '52.
Next up, tear it down, plumb car and wire all for EFI.
Will she all fit? Thats the million dollar question i should know the answer to this spring!
'72 super
'65 bus
'52 split
Old December 12th 2012, 21:41
Fantastic find Pete! Hoping to join you this spring.
Old December 13th 2012, 04:00
petevw's Avatar
Hey Sandeep! Heard a rumor you are back in the scene.
'72 super
'65 bus
'52 split
Old December 13th 2012, 09:06
Will it fit? I still have the big 6 foot "Shoe-horn" it used for the Herbie-X. LOL.
Old December 13th 2012, 11:58
Nice! (pls try to fit an intercooler of some sort)
Old December 13th 2012, 22:04
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What pump are you using to scavenge the oil from the turbocharger?
Old December 24th 2012, 03:48
petevw's Avatar
Turbowerx:
http://turbowerx.com/Scavenge_Pumps/.../Exa-Pump.html
'72 super
'65 bus
'52 split
Old December 24th 2012, 22:39
Bug@5speed(US)'s Avatar
So please school me on these scavenger pumps.
Assuming since turbo is below th pan, there is no way for gravity to help with allowing turbo oil to drain properly?
Is it common to have the out let drain to where the oil dipstick or vent would go? Need some clarification on why, the outlet does not feed into oil pan area? Can this be used this way with a dry sump setup?
Pondering this approach for a type 4 in my bug down the road.
Thanks in advance,
Ps last question before Xmas �� with regard to the hours discusses on the pumps website, are these rebuildable or does one need to send out for 10k hr intervals?
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old April 9th 2013, 07:16
petevw's Avatar
Hi Dave,
Had the trans out of the bus for a 2nd gear down shift grind issue. So since the engine was out, and we had a local dyno day, I brought along the 2276 to play. The engine made 140hp and 130tq. Not too far off the numbers you ran on Jake Raby's dyno many years ago.
'72 super
'65 bus
'52 split
Old April 9th 2013, 07:21
petevw's Avatar
Thanks in advance,
Hi Alex,
I wouldn't know if this pump can be used as a dry sump pump. Decided to drop the oil back into the engine fr the filler spout because it was convenient. There is way to much going on around the sump with this type of header. As for the pump being rebuildable? Don't know. This pump was suggested to be used be a engine builder friend. He has had good experience with them, with no failures.
'72 super
'65 bus
'52 split
Old April 9th 2013, 07:22
petevw's Avatar
Work will start again on the '52. Need to get the trans and motor back into the bus in the next couple of weeks.
Can't wait.
'72 super
'65 bus
'52 split
Old June 15th 2013, 13:15
petevw's Avatar
Back to working on this.
Never liked the plastic fender to body gasket. Ordered up the cloth fender welting many years ago and finally got to swapping it in. I didn't like the pre-cutouts of the plastic for the bolt locations. So I punched holes instead and installed. With the holes, it bunches up around the radius which I don't mind as the cloth is in contact all around.
Last night installed the Uniball plates I made. Took pic as I was installing so as you can see bolt missing and loose. It is completely bolted up now.
Have been looking for this MB SLK 55/65 spare wheel for awhile. Have an idea that I want to try. We'll see how it plays out.
'72 super
'65 bus
'52 split
Old June 18th 2013, 08:11
petevw's Avatar
Carbon crotch coolers installed:
'72 super
'65 bus
'52 split
