Old April 26th 2013, 02:27
coolrydes coolrydes is offline
Originally Posted by Birdman69 View Post
The Mendeola and Subaru Trans shift couplers are just a band aid job.
If you look how it mounts with that plate, when you rotate the shift rod through the left / right plain the shift rod rotates over the subaru shift rod and is hardly presise.
I am supporting the end of the rod, then running two small universals with a diagonal shaft to bring them together.
In a suby trans install, the shift rod on the trans is about 2 inches off centre.
http://www.subarugears.com/image622%20-%20Copy.jpg
FYI, Birdman
Ours seams to be working realy good.... I don't see it as a band aid and it works smooth... But you just keep putting and over thinking simple things....
Old April 26th 2013, 02:46
Birdman69 Birdman69 is offline
Originally Posted by coolrydes View Post
FYI, Birdman
Yes Kevin it certainly does "work" but holding your hood down with a bundgy cord (i think tha's what yanks call an occy strap) also "works"
If I was spending $435 on a high quality billet shifter, I would want the best solution for the other end of the shift rod too.
I wont bother detailing the many issue one would encounter over time.
Why don't you answer my question on the Samba so I can buy your product?
and try to stop burning potential customers!
