Old June 2nd 2014, 16:27
Rule09 Rule09 is offline
Nice!
Old June 4th 2014, 01:16
Looking good Wally! Were those custom made for you?
Old June 6th 2014, 08:21
Shock porn.
Old June 6th 2014, 08:29
Yeah, almost shocking!
Mark: not custom for me, its just a (top of the line) 944 aftermarket part. Not really a shelf part tho, as I had to wait a few months for them to be made.
Old June 12th 2014, 05:01
graham's Avatar
graham graham is offline
Mythbuster: continuing project thread of my 1303 '75
Those Koni's look awesome Wally,are those racers edge lower shock bolts ?
gee dub
Old June 12th 2014, 05:17
Yes, they are
Old June 13th 2014, 01:24
graham's Avatar
Thanks Wally
gee dub
Old October 12th 2014, 15:44
With the new shocks, I also decided to change the arms from turbo to regular n/a 944 ones for a little less track width.
Here you can see where the difference in width (1 inch or 25mm) comes from. The arms themselves are the same casting ;-)
Old November 8th 2014, 19:19
Mounted my old front disk set-up to the rear where it originally came from. Also test mounted the rear coil-overs:
Old November 10th 2014, 12:38
Hi Wally, good to see you back on it!
I'd have to see the vent design but it looks like you have the disc on the wrong way around or the wrong side (the bell is obviously correct)...
Rich
Old November 10th 2014, 15:41
Richard,
You are absolutely correct! I used to think this was more logical, but factory indeed mounted them the other way round.
Old November 24th 2014, 14:18
Old November 24th 2014, 18:33
Did you have them all mounted backwards?
The logic is that air flows radially out through the disc, so in by the hub and out by the wheel rim, having them the other way around effectively tries to oppose the normal airflow by scooping it back in resulting in poor cooling..
How's the new engine coming along?
Old November 25th 2014, 04:20
The above pic is from the front left wheel, so that should be mounted correctly?
The engine building is holded till funds allow further progress...
Old November 25th 2014, 14:38
Yes, I saw the front left was correct, just wondered whether you had mounted them all as the rear were..
Look forward to more progress
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
