Old April 13th 2017, 06:12
petevw's Avatar
petevw petevw is offline
Whoa, nice build!
'72 super
'65 bus
'52 split
Old April 15th 2017, 15:06
Nice updates! Still on the GRX3076R ?
Old April 16th 2017, 21:49
Thanks Petevw
Still the same GTX3076R turbo but with the .63 rear housing, not long now
Old April 25th 2017, 16:05
Thanks Petevw
There's your limit I think.
Old December 17th 2017, 01:06
Hey Steve, how is your build going?
Old December 19th 2017, 05:00
Its good to be back, thanks to everyone that worked to get the site going again. I will need to fix my photos up that are hosted on Photobucket
A lots been happening with my bug. I had the car back on the road for a few days and bent a rod, my fault, I got a bit carried away and drove it through a missfire.
So its a fully forged strocker motor, 2.5 crank, Argo rods, Manley pistons etc 2142cc it made 305 kW on 29 psi, Tomei cams are now responding to tuning thanks to a new ECU, it also made 200kW at just 4,500 rpm, the torque is amazing.
I also fitted an Accusump and Radium fuel rails and dampener.
Ive loaded a dyno photo, not sire if it will work, Red blue green 3 boost settings. Pink is old setup
Old December 19th 2017, 05:02
PS, photo loaded OK so I will load some more and update old posts
Old December 19th 2017, 06:30
A few extra photos, Accusump
Old December 19th 2017, 06:34
Radium fuel rails and fuel dampener
Old December 19th 2017, 07:01
After my Beetle crashed into my sons Beetle we did an update on it, Aero kit the same as mine, he borrowed my wheels for a while. Were building Oxy boxer for it, 82x94, Street elims, 48 IDFs dry sump etc
Old December 19th 2017, 07:25
Nice car for sure!
Steve, what is the benefit of a fuel damper?
Old December 19th 2017, 16:30
H2OSB H2OSB is offline
Two amazing looking cars! Love the idea of the oxyboxer. Unfortunately for me, I can't install an oxy for the same reason I can't do a Suby mill...don't have the guts to cut up my car. Maybe if I could just find the right radiator set up.....
johnL (aka H2OSB)
Old December 19th 2017, 23:55
I needed a fuel pulse dampener because Im running ID 2000 injectors and when they open & shut they cause a chatter in fuel line which causes a rough idle.
http://www.radiumauto.com/Fuel-Pulse...Kits-P751.aspx
John, the idea of going Oxyboxer is that will be essentially an air cooled motor, a WBX with no water jackets.
When I sold my 1302 and fitted an air cooled motor in place of the WBX all I had to do was fit a new spare wheel well to get it back to standard.
Old December 20th 2017, 00:43
I knew that. I guess I gapped out a bit. I was looking into an Oxyboxer crank into a T1 for a while, but I've gone pretty far down the T4 road, so I decided to stick with that. The jacketless WBX makes a nice motor, I just don't have any of whats needed to build one and don't feel like cutting my losses with the T4 parts.
Anyway, both you and CaveDarter have nice rides!
H2OSB
johnL (aka H2OSB)
Old December 24th 2017, 14:21
tnx! learned somethink again :-)
You run E85 now (because of the 2000cc injectors)?
