Old August 29th 2006, 10:17
64bug's Avatar
64bug 64bug is offline
Yes that is the point. I got my calipers,hups, backing plates, e-brake parts, everything but rotors (because i wanted new) for $700.
Old October 19th 2006, 18:47
spooky spooky is offline
Originally Posted by elroocky View Post
Nothing special, a complete set of brakes for a 944 font in a junk yard, I've refreshed the all batch and installed it, all the rear is a "plugg and play" , you just a have to modify the end of the kand brake cable, for the front, I'm machined a set of CB perf springles and the 944 and welded both together...
I drive that car since many year without any problems...
please can you explain the modification required to the hand brake cable?
ive got front and rear kits on order from franklins vw werks and not sure if handbrake cable is included... thanks!
Old October 23rd 2006, 01:39
64bug's Avatar
The porsche has differant connecting end for the e-brake pad spreader arm(lack of a better word) then vw. 944 uses a pin/clip, vw uses a hook. Theres adapter arms that use vw cables (Lanner has them www.vdubengineering.com ), I cut mine the welded the porsche ones on the vw cable. (not the right way to do it, but it work... For now...)
Old October 24th 2006, 02:39
Eliasson Eliasson is offline
e-brake
Hello
I used the original e-brake cable from 1302/3. I cut off the bar between the sides, and drilled a hole. You see the result in the picture.
It has work so far.
// Eliasson
Old November 16th 2006, 21:38
64bug's Avatar
i tried to do the same thing, but it didn't leave me with enough material. (comfortably anyway.) seems like it wouldn't last that long.
Old November 17th 2006, 14:19
buggyboyshane buggyboyshane is offline
guys how did you mount the disks and calipers on the rear. i have the full setup inc rear handbrake bits from a 2003 3.2 's' boxster, and am wondering do i need to make a plate to attach onto the end of the rear axle where the bearing housing goes, around which my handbrake shoes can sit or wha....?
Old November 17th 2006, 16:18
You need the other bits from an early 944 or 924s..
Rich
Old November 24th 2006, 17:52
what other bits rich?
Old November 24th 2006, 18:52
Bullyboy Bullyboy is offline
#23 attaches your brakes to the beetle trailing arm
Old November 24th 2006, 22:16
64bug's Avatar
yep you need all that. Thats the single piston set up but it shows how it goes together.
Old November 25th 2006, 15:04
dont spose you have a part number for that back plate?
