Old May 29th 2006, 09:03
spooky spooky is offline
944 brakes on Oval
So im told this is the place to be ragarding porsche brake upgrades!
im also told im restricted to pre-87 single pot 944 brakes since i want to fit 15" fuchs. Anyone got some decent pics of this conversion?
thanks!!
(my first post! )
Old May 29th 2006, 23:16
Pillow's Avatar
Pillow Pillow is offline
Yah, with the 944 single pots you need to run 15"+ wheels.
Sounds like a fun project though! Early cars with a little modern twist are sweet.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 30th 2006, 19:17
SoCalGL SoCalGL is offline
ha welcome to my world... its not a oval but a 69 standard irs and i was looking into running fuchs but 993 brakes just won't fit.. and i could'nt find an american torque thrust that were a porsche pattern...so my some what cal looker is turning german wit porsche boxster wheels..
Old July 2nd 2006, 02:51
elroocky's Avatar
elroocky elroocky is offline
done on my 1200 and my 54 oval...
it's a rather very easy job, take a good dayif you have all the parts
no problem with 15' rims, steel 356, gasburners or fusch, it fit's
ride a type4.. it will change your life.....
Old July 2nd 2006, 06:30
excellent! what parts did you use?
many thanks!
Old July 2nd 2006, 07:06
elroocky's Avatar
Nothing special, a complete set of brakes for a 944 font in a junk yard, I've refreshed the all batch and installed it, all the rear is a "plugg and play" , you just a have to modify the end of the kand brake cable, for the front, I'm machined a set of CB perf springles and the 944 and welded both together...
I drive that car since many year without any problems...
Old July 2nd 2006, 20:20
Danborn's Avatar
Danborn Danborn is offline
Hmm.. I'm running 4-pots with 6"x15" Fuchs! I only needed 6mm spacers
It fits like a glove... Even with a normal front beam..
Jesper
Old July 10th 2006, 09:18
martinpye martinpye is offline
944 Brakes
Hello
I have recently purchased a 1968 beetle cabrio and I am looking into installing 944 brakes. It sounds from the previous threads that single and four pot calipers are ok with 15 inch fuch alloys. Does anyone know if brakes from a 944 s will fit. These have abs fitted. Is it better to get the pre 87 brakes circa 1987.
Thanks for your help.
Old August 21st 2006, 22:43
V0LKSWAGENSRULE V0LKSWAGENSRULE is offline
Jesper
Attachment 2212
Attachment 2213
Attachment 2214
Attachment 2215
This is exactly what I'm looking to do for my Oval...
I want upgraded braking, but want to stick w/ 15" Fuchs (earlies).
What parts did you use for everything? I would prefer to use new (if available) parts.
Thanks!
~Dave
______
'55 Ragtop
Needs: TLC
Old August 24th 2006, 01:11
64bug's Avatar
64bug 64bug is offline
new? You must have money to burn, Those calipers are $500+ each new. New rotors and pads is one thing but....
Old August 25th 2006, 19:06
Wow, I didn't realize they were so pricey.
I really want the look of Big Reds, and this is a project.
I guess I'll start saving my lunch money now
~Dave
______
'55 Ragtop
Needs: TLC
Old August 25th 2006, 20:20
64bug's Avatar
Big reds are even more. I bought used calipers and painted them up see here. http://www.germanlook.com/Forums/showthread.php?t=7571 with new rotors. Nothing wrong with good used parts.
Old August 29th 2006, 00:05
Your brakes look superb! You should do a write up/article for the Tech section!
I see you stuck w/ Link Pin suspension, CB performance (lowered?) spindles.
That's my plan. I guess I'll have to stick w/ Boxster calipers to fit under my 15" fuchs.
What size rims are you going to run?
~Dave
______
'55 Ragtop
Needs: TLC
Old August 29th 2006, 01:13
64bug's Avatar
Thanks for the compliments. My 15" phonedials didn't fit so i'm going to 17" twists. I yes they are cb drop spindles, You can get away with with "certin" 15"s with a combo of spacers and "machining " calipers slightly, but not for me or my steup. Good luck with them.
Old August 29th 2006, 08:29
i think the point is that you don't want to buy "new" ones. hit a junk yard or parts house and pick up a set of used calipers and associated hardware. you can pick up a whole set used cheaper than one caliper new.
