Old August 8th 2009, 04:20
There was a very empty highway road last evening, no cross-winds at all and I kept my foot down a bit longer this time: 219,6 km/h or 135.5 mph:
Old August 8th 2009, 06:46
blitzvw's Avatar
blitzvw blitzvw is offline
Originally Posted by zeroaxe View Post
Pffffttt!!! You said that the other day too about another car!
Nooit man! Dit was nie ek nie!
Blitzem with Type 4 power
Old August 8th 2009, 15:07
How stable did it feel Wally?
Old August 8th 2009, 17:19
Actually it was just fine, even without the much needed extra caster I still need to adress; I even had time to check the speedo
No wind, flat road also helps a great deal.
Old August 15th 2009, 16:50
Just back from a 'last-minute' Ring visit. It was a great sunny day, not too busy and we had great fun. Did 4,5 lap today with a passenger!
Old August 16th 2009, 01:02
Now that is a great shot. Sure wish I could run over to the ring take a lap or two.
Old August 16th 2009, 05:57
Well, you could plan a holiday around a Nurburgring visit (like I did)
Gonna bore you with some more shots I found on the web:
Old August 16th 2009, 06:00
Old August 17th 2009, 03:23
Old August 17th 2009, 12:29
Humble's Avatar
Humble Humble is offline
I love the pic of you leading the porsche through the carousel, great pics man!
Old August 17th 2009, 13:33
Wally - your car has made me wonder if I should ditch my widened wings and go with some wide and flared...
And the more that I look at it, the more I like the duck tail too.
Is your airdam a CSP one or a home drilled?
Al
Old August 17th 2009, 14:02
chug_A_bug's Avatar
Love the Pics have it set has my computer Screen background
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old August 17th 2009, 14:07
Tnx guys
Al
Its an original ('NOS') kamai and I home-drilled it, yes
Old August 17th 2009, 18:03
Hi Wally
Great photos. What is the smoke haze around the car from?
What sort of speeds do you get down the long straight before start/finish line?
Old August 18th 2009, 02:03
Its the right front tire rubbing inside the fender...
I already ordered some coil-overs with adjustable lower spring perches.
Funny thing is, I never had that on any track or event I drove before. The Ring surely brings out any imperfections, even small ones. Running with all sorts of luggage in the front trunk and a passenger also helped squeeze down the bump stop beyond normal limits probably.
As you may know just about after the last bridge crossing, your supposed to slow down for the gates at the start/finish/exit point and max speed signs are present, but I usually like to keep my foot down till right at the bridge where I cross at about 190 km/h or just under 120 mph. The ' straights' just after Hocheichen and after Aremberg are also very high speed parts. Car stability is essential there as 120 mph on a straight flat highway is soooo different then anywhere on the Ring... and the official straight passed start/finish is never possible to run full by due to the Touristenfahren start/finish halfway that straight. Pity though.
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests)
