Old June 17th 2011, 04:00
judgie's Avatar
judgie judgie is offline
very true walter , my car is set up for what are pretty rough [for tarmac] and tight hill climbs sprints. no good having very stiff suspension as the bumps and camber changes mean you need quite a lot of suspension travel.
spend most of the time in 2nd or 3rd on the hills only a few tracks that i use 4th. just about ever track has a 1st gear hairpin so good mechnical grip is needed hence the softish suspension.
hopefully the lsd i have now fitted will improve it even more out of the slow corners but i can see some changes being needed to set up and driving style now its fitted.
Old June 17th 2011, 13:45
Originally Posted by wrenchnride247 View Post
Let me post a pick of mine (again ) for you to look at Wally...
Thats what I'am talking about! Did you get the 25%/75% or the 40/60?
Good choice mate
Old June 19th 2011, 08:07
Someone did a compilation of the Time Attack event:
http://www.youtube.com/watch?v=cU8FT7E3JCg
and here at appr. 0:45 into the vid a drive-by onto the straight in the warm-up session:
http://www.youtube.com/watch?v=ZUMLVx5f9tU
Old June 19th 2011, 22:55
Good choice mate
The lesser of the two. They didn't advise too much lock up on the street.
Old June 20th 2011, 02:09
That would be the hardest part for me to decide upon tbh as I do some track time as well plus I absolutely hate the one-wheel burn-outs at drag events (which are dangerous too).
Old June 20th 2011, 21:50
They would do 60% but said it would be too unpredictable on wet ground. And it would wear tires fast. They HIGHLY discuraged 60% for the street. If I can ever get my project going again I could tell you how fun the GT diff is.
Old June 21st 2011, 02:25
Wasn't talking about 60%, but 40%
See ^^
Old June 21st 2011, 08:55
Always good to watch videos from Wally. Thanks.
Old July 6th 2011, 16:40
One of 'those' one wheel burn-outs, this time at Budel june 2011. Won't do this anymore till I got a diff.
http://www.youtube.com/watch?v=1FVs5O3uJoQ
Old July 7th 2011, 10:02
Nice burnout Wally....you made enough smoke so you can´t really tell it was only one wheel
Old July 7th 2011, 10:47
TSAF's Avatar
TSAF TSAF is offline
Wally POWER
VW 1303s 1975 (German Look)
VW 1300 1964 (Rally Car)
LAND ROVER DEFENDER 90 V8
BMW E30 318i CONVERTIBLE 1992
Old July 7th 2011, 23:50
Nice work Wally.
Old July 8th 2011, 03:07
TSAF's Avatar
Wally burn rubber not your soul
Old July 8th 2011, 19:57
Luismj's Avatar
Luismj Luismj is offline
wow Very nice burnout!
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
Old July 9th 2011, 04:33
Bruce. Bruce. is offline
I hope that was a cheap tyre Wally
Back to your circuit handling.... Have you tried measuring your tyre temps after some hot laps? Infrared temp guns are really cheap now and by checking the temps at the inside, outside & middle of the tread you can figure out how the tyre is hitting the road in the bends. If you can find a handling pad to run constant circles until the front tyres start to go off (overheat) you could learn a lot.
