Old August 23rd 2013, 11:22
Gerrelt's Avatar
Gerrelt Gerrelt is offline
I'd love to get details on the roof spoiler and the rain gutter panels you made.
At your service: Link to germanlook thread
And here I describe how I created the A pillar deflectors: Reducing Windnoise / Raingutter Fillers page
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old October 31st 2013, 15:11
Ok, so I disposed of almost all of the type 1 stuff and started cleaning a type 4 case again
The idea is to use my 74mm Oettinger crank coupled to a moderate bore of 98mm to give 2230cc or almost as 'big' or small as the old motor was.
This time with "someones" billet type 4 heads with T1 exhaust ports (if all plans and promises are met) for improved flow and strength.
Almost everything on the engine will be a little stronger or better in some way, so I'am curieus what the outcome will be!
Old October 31st 2013, 15:21
Good to see you back into it Wally!
Old October 31st 2013, 18:33
Good to see that you are continuing your quest, keep us posted with your progress
Old November 1st 2013, 04:18
judgie's Avatar
judgie judgie is offline
watching this one with a lot of interest. with what you proved with the last engine and the knowledge you gained from it this could be a very impressive motor.
Old November 1st 2013, 05:59
Welcome back Wally! The billet heads will be introduced this weekend so I´ve heard. I´m really looking forward to this!
Old November 1st 2013, 15:15
effvee effvee is offline
What type billet heads?
Old November 1st 2013, 17:17
Aircooled type 4 billet heads
Old November 1st 2013, 21:26
haha come on Walter, you have me chomping at the bit, who makes the heads do you have any pictures sir
Old November 2nd 2013, 12:18
-Alex- -Alex- is offline
Similar like these E Plus heads at cal-look lounge..?
http://cal-look.no/lounge/index.php/...html#msg271836
Old November 2nd 2013, 15:30
Definately similar, but surely not the same
If the manufactorere says ok, I'll post some pics of the drawings. Heads still need to be made..
Old November 5th 2013, 03:43
Clatter Clatter is offline
Can that case still be good after being subject to the past abuse?
Spread center main?
Pounded out/line bore needed?
Dying to see how the case looks.
That last crank was a stock 1.7, right?
Just balanced, no counterweights, IIRC.
If you can just use the case as it sits, it would speak very highly of the setup....
Old November 5th 2013, 03:53
Spread center main?
This is another case. I sold the former 2,2 engine as a N/A set-up, but if you go back some pages you'll read that I have openend the engine to change a few things (cam, rods) and that the case was even inspected for hairline cracks and all was good to go again. Even bearings were still good and could have been used again. I replaced them anyways though back then.
The crank was indeed stock 1,7 re-hardenend, polished and balanced. Nothing more.
This time it will be 8mm more stroke, chro-mo forged & counterweighted
Old November 5th 2013, 09:55
I look forward to more riveting updates from you Wally.
Old November 12th 2013, 15:05
Cheers mate!
Left: new case have bolts (12.9, 10mm diameter)
Middle: Original head studs (7.2mm diameter)
Right: Raceware head studs (9.0mm diameter)
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
