#1561
Wally,
How much ground clearance do you have with the exhaust header setup the way it is? |
#1562
As the car sits now (I just measured for you) almost 5 inches (12cm). Silencer is a little over 4 inches..
#1563
[/QUOTE]Now I see which way it is going. Cool design
VW Super Beetle 1303 1973 Kolibri Grün Metallic |
#1564
Hi Wally
Looking good. Is that an OEM oil cooler or an aftermarket one? Does it fit behind the rear apron without any modification? I'm asking because I'm yet to source an oil cooler for my sons Beetle. Steve
#1565
Wally, what do you use for lines for the oil cooler, and how have you routed them? -10AN I'm presuming?
#1566
The guy in Poland had 2 or 3 of those... It fits so snug directly behind the front apron and the spare wheel well, that I didn't even need mounting tabs or something! I just ty-wrapped it to both outer grill mesh holes ![]() Oil feed from tank in the nose to engine is AN12. Oil suction and back to the front oil cooler and then tank is just 1/2" (13mm iirc) inner diameter oil line. No problem like that for over 13 years now with all engines
#1567
For those that don't do FB or STF, I got the engine on the dyno yesterday and it did even better then I expected!
![]() 244Nm @6K and 226,5 CHP @ 7K with the low CR engine with air filters, muffler and horizontal fan belt running up to 8K made me very happy ![]() https://www.youtube.com/watch?v=LKhbYc0gOGY |
#1568
nice
#1569
Just a pic from early this year just out of hibernation ;-)
#1570
Walter, I love your 1303
Granted, I am a bit partial
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) |
#1571
Haha! Thanks man!
#1572
Yep..
Just wanted to chime in that i read the whole thread again over the last few evenings.
Thanks for the inspiration. |
#1573
Haven't been here in a while, but for those still here: after the re-install of the whole turbo set-up, it made 475 hp at 1,6-ish bar boost on gasoline, 0% Ethanol, gas (the higher octane of course) bought at the pump here in Netherlands.
At Santa Pod I finally reached my long time goal and it ran a 10,58 seconds in the 1/4 mile at 130mph! Way more then I anticipated. I drove there, camped at the track and drove back home again on my own wheels - as I had always planned. ![]() ![]() https://www.youtube.com/watch?v=9LI-_7aQIIw Last edited by Wally; November 11th 2022 at 14:32. |
