Old August 4th 2003, 12:23
SuperRSi's Avatar
SuperRSi SuperRSi is offline
wrong rear hub?
My late model 944T trailing arms were cobbled together from several sources. I bought the "trailing arms" on-line and when they arrived all they really consisted of was the bare trailing arm. Soooo, I took them to a local wrecking yard/ Porsche shop and they assembled the set. Now the problem is when I put the rear rotor on the hub it does not even begin to cover the parking brake pads. So I guess my question is wrong hubs or wrong rotors?
Thanks,
Randy
Old August 4th 2003, 12:31
Alex's Avatar
Alex Alex is offline
Well...it is either or!
Those hubs are from the late style al arms. You need to get disks for those. Your track increase will be a lot bigger with those.
YOu might have early style disks and this is why they do not cover the e-brake shoes.
I would try to source some early style hubs. They sit flat on the al trailing arm and do not come out on a cone like this one in the pic.
Old August 4th 2003, 12:46
SuperRSi's Avatar
Wow the answer took several minutes...
I will take them off and head out to find the flat hubs.
Thanks again,
Randy
