Old June 17th 2005, 04:55
trevorbrady's Avatar
trevorbrady trevorbrady is offline
Originally Posted by ricola
I thought it was all going to be simple for an 03 too, but when I researched it isn't just a case of swapping over the spindles and using Kerscher ball joints.
There is also:
+ve camber in the Porsche spindles needs correcting (triple C camber bolts?)
Extending the tie rods
track increase (need late 03 parts which are wider and the brakes add another 10mm per side?) Only early spindles have the speedo cable hole in them.
I think a tech article is needed!
Rich
Amen to that! I bolted up my 944 N/A brakes last weekend and discovered these problems too. The general word is that N/A brakes will just "bolt-up" when you use the Kerscher ball joints, but there's a lot more to it than that.
Could the track control arm be made adjustable by welding in an adjustable rod in the middle? This would allow you to fine tune the camber pretty easily. If this was done, would there be difficulties with the top of the strut binding or is there some "flex" up there that would allow the track control arm to be lengthened?
