Old June 8th 2005, 07:05
Racelook's Avatar
Racelook Racelook is offline
Hi Trevor,
They're originally silence blocks, the are used to mount an motor on an platform or in a truck. The ones that are used for the original mid-mounts have an diameter of 50 mm and an height of 45mm.
Maybe for you, because you don't want to use an noserubber (if i understand right), you better could machine some urethane bushings with that length and diameter.
Greetings Wiebrand
B-Extreme B-Tuning.....
Old June 20th 2005, 14:44
Racelook's Avatar
YES YES, finally the Cup-strebe completely ready!!! Whieeeeeeeeeeh
Friday I also picked up some steal for the bracket so I can make the hydraulic handbrake.
Picked up some fittings for my HRC (for the hydraulic handbrake).
The old bracket for the original handbrake removed.
And also an drwaing given to somebody for making some pieces for the hydraulic handbrake.
On saterday also given an drawing to somebody for making my brackets for my highwinhg.
Old June 20th 2005, 14:45
Racelook's Avatar
And on sunday it was Budel 2005.. what an great show and what was it hot.. Burned to the skin YEAAAAAAAAAAAAAAAAAHHH
Final result of the Cup-strebe.
And an quick pic of the removal form the original handbrakebracket.
Wiebrand
Old June 21st 2005, 07:24
tom'72's Avatar
tom'72 tom'72 is offline
nice work there, but why did you remove the handbrake bracket?
Old June 21st 2005, 14:32
Nice brace :agree:
Old June 22nd 2005, 10:35
Racelook's Avatar
So I can make an new bracket for my hydraulic handbrake (which I'm also gonna make my own)
Wiebrand
Old June 22nd 2005, 10:36
Racelook's Avatar
Thanks for the nice comments guys! That just keeps me up.. to finally finishing this car THIS year
Old June 22nd 2005, 16:37
Al B Al B is offline
That's fantastic Wiebrand!
some really well thought out ideas there keep up the great wotk and keep us all informed!
Al B
Old June 22nd 2005, 21:47
LLVWGL LLVWGL is offline
Very nice work, butI have a question about the fuel line. What wall thickness tubing did you use?
Old June 23rd 2005, 04:56
Racelook's Avatar
1 mm..
The tubes are 12*1mm
Wiebrand
Old June 24th 2005, 07:11
Racelook's Avatar
Tuesday I got an ring of my metalworker that 2 pieces for the hydraulic handbrake were already ready. So I picked them up and here are some pictures.
Everything is in raw measurments and will be made on the right size when needed.
Wiebrand
Old June 30th 2005, 02:07
BAVWCJoel BAVWCJoel is offline
hey racelook, what kind of ends are those on your brace? curious, because my dad and i have been trying to build a brace similar to yours only we were going to use balljoints.. and those aren't cheap so i was curious as to what kinda ends those were.
Old June 30th 2005, 04:03
Racelook's Avatar
In dutch the are named as; gaffel M10
There only available in right tread, so left tread has to be machined in them.
Wiebrand.. the are alsmost 7 euro each (in Holland)
Old July 6th 2005, 18:43
Racelook's Avatar
There's another update.
Today I brought the camera with me so I could make some pics of the little progress I maked the last 2 days (I'm now closing an verry verry bussy period with school, so my spare time finally can be used for my bug)
Sorry for the green pics but this is our "Turtle-camera" (after an fall).
Yesterday I had welded some metal plates (hooks) for the front controlarmsbrackets that will give some mores strenght. Tomorrow there also be welded some of that plates on the top of that brackets.
Today I was looking for an aluminium "crash-plate" for the underside of my chassishead (so something of the car stays complete when I hit an traffic-humb). But this costed 3 euro/kilo at the "old stealman" so I have to find antoher solution for that.
Yesterday evening the gearbox was stoomcleand. This is the result.
Yesterday also welded the hydraulic handbrake-bracket together. And luckily everything works also :wink: (everything except the HRC is handmade). Also an wooden mold made for the handbrake-lever. For this handbrake several things were made tonight and will be completed in the next couple of days. The handbrake is for 60% ready.
Today I only maked some plates for the front control arms. SO it was not an quite productive day, but I soon have more spare-time.
Wiebrand
Old July 7th 2005, 11:56
Racelook's Avatar
So this morning (before I had my diploma-delivitration) welded some more metal plates to the front controlarm-brackets.
Some more pics.
http://www.keversite.nl/fotoalbum/fo...2005173822.jpg
http://www.keversite.nl/fotoalbum/fo...2005173841.jpg
Also had an little bit done to the midmount
Greetings Wiebrand
