				Project "Racelook"
			So I thought I can better open an new thread for my bug. I'm restorating/building my 1303 S from 1974
			I'm now more than 2,5 years bussy with this resto. This is how it stands now:   At this point the follow things are done: Chassis: -Every rust is out. Several pieces of framehead, napoleonhead self made, 2 new floorpans welded in. Two 12mm fuellines installed (what an work was that, but there in). I'm now at the point where I'm bending my 6mm RVS brakelines. (after that the chassis has to be maked clean to bare metal and will be sprayed with paint) Body: -Every rust is out (after many, many hours of welding).. maybe there's some little spots left, but they will be welded when I make the body clean to bare metal. -Race-fuelfiller from Sparco is in. (also lots of work with the home made holder for it) -After 2 pair of verry crap doors, finally got 2 good doors. Both of the doors are smoothed, so there are no doorhandles anymore. (will be opend eletric) -The enginelid is changed for an lid of an 1300 (without vents in it). I've started with making an metal scoop on it (almost 3 months ago, but has not finished it). -The Remmele side-airscoops are "in", everything is prepped for the installation, they only have to be glued in. -An aluminium is also from the beginning of this project in my property. CAD/CAM drawings for new wing"foots" are ready and waiting to be machined (laser cut). -An full rollcage is made by our self, more details can be found in this topic: http://www.germanlook.com/Forums/sho...light=rollcage -Hole the body is cleaned from inside and outside. Every hook is smoothed, every not functional hole is close. -Eberspacher heatchanger lays ready -Kamei-spoiler lays ready -Engine and gearbox will be for this time only been cleaned and painted. -Stripping the paint and all the body work has to be done. I will update this topic as fast as I can. Greetings Wiebrand
			B-Extreme B-Tuning..... Racebug is comming to get ya!!! Last edited by Racelook; May 11th 2005 at 18:23.  |
			Sweet project Weibrand. Looks like it's coming along. Mine has taken almost 5 years. Good to know I'm not the only one who took the long way round!
	72 Standard- 1600 stocker..for now It's YELLOW Rolling on a daily basis. VKG  |
			So my first update:
			This are honestly just pics of about two weeks ago (when I had some time). I've been busy (so I said in above answer) with putting in two fuellines of 12mm (where originally sits 1 of 6mm) in. It was verry verry ****ty work, but hell yeah someone got to do it. At first an pic on which the holes on the backside are good to see. Also are the tules en the cut out piece verry good to see to get the lines in. ![]() An detailpic. http://www.keversite.nl/fotoalbum/fo...2005232611.jpg To really get fuel from the front to the back they have to have an exit on the front. http://www.keversite.nl/fotoalbum/fo...2005232701.jpg After thtat both sides where welded close. -Backside http://www.keversite.nl/fotoalbum/fo...2005232741.jpg -Frontside http://www.keversite.nl/fotoalbum/fo...2005232836.jpg After a lot of "playing" with the Dremel I get this ending result. -Backside ![]() -Front ![]() I think it looks verry nice, just like off fabrique Wiebrand
	B-Extreme B-Tuning..... Racebug is comming to get ya!!!  |
			Looking good Wiebrand !
	I think I might have to get the body off the frame too next year. What's with the 2CV (Eend), are you fixing that one up too ? Rob.  |
			thats BIG fuel line
	www.subynotch.com  |
 2CV is from an uncle and is an donorcar for other 2CV's he's restoring. Wiebrand
			The strengthen gearboxrubbers I picked up last Friday at Franky's VW Service. I now only have to make an bracket to mount them on 8) .
			![]() Wiebrand
			So, the breaklines are finally in. It did go quite good, exactly the long tube was verry tiedy to bend by the HRC.
			Back ![]() http://www.keversite.nl/fotoalbum/fotos/16052005233221.jpg Front ![]() http://www.keversite.nl/fotoalbum/fotos/16052005233351.jpg Goes quite nice! ![]() Greetings Wiebrand Bunt p.s. excuse for the green pictures.
			Hahaha, it's almost like it
   Looks that way to me too.
	Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny...  |
			So guys it's time for an new update.
			At first some clear pics of the install of the brakelines. Back http://www.keversite.nl/fotoalbum/fo...2005224114.jpg http://www.keversite.nl/fotoalbum/fo...2005224159.jpg Front http://www.keversite.nl/fotoalbum/fo...2005224301.jpg Some steel and silence blocks for the transmission mid mount I'm gonna make. ![]() Steel and other stuff collected to make my own Cup-strebe.
			The packet that came from Topline.
			http://www.keversite.nl/fotoalbum/fo...2005224642.jpg This was in; http://www.keversite.nl/fotoalbum/fo...2005224932.jpg Everything out packet gives this; ![]() Polyurethaan for al moving stuff for my chassis. And today also begin with the making of the transmissionmount for the Cup-strebe. ![]() ![]() I've welded two more pieces of steel in (in comparision with mount from other "factory's") for extra strength at the points were the tubes of the Cup-strebe will contact. Looks nice huh? Greetings Wiebrand
			So yesterday finally had some time to work on my car.
			At first I maked some changes at the gearboxbracket. ![]() Another shot. http://www.keversite.nl/fotoalbum/fo...2005220652.jpg I attached the stronger noserubber to the gearbox and mounted it to the chassis. http://www.keversite.nl/fotoalbum/fo...2005220947.jpg First tube of the Cup-strebe is ready (still 4 to go). ![]() A view from above http://www.keversite.nl/fotoalbum/fo...2005221443.jpg Front http://www.keversite.nl/fotoalbum/fo...2005221540.jpg That's it for now. Greetings Wiebrand
 what are these rubber mounts from? I need a pair of these to make a front mount for my 915-1303 installation.
	Subaru powered oval/1303 hybrid project  |
