Old February 25th 2007, 13:51
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Is that a Boxster exhaust/muffler?
Thanks,
Randy
Old February 25th 2007, 14:24
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
Yes, the exhaust is from the Porsche Boxster
Old February 25th 2007, 19:01
oasis's Avatar
oasis oasis is offline
:agree: Beautiful car. :agree:
Old March 9th 2007, 07:11
1303 1303 is offline
I am attempting to fit a 9" 993 Cup III with 55et wheel under stock rear guards. I have a 26mm spacer and have had to cut the bump stop. the tyre currently on the rim is 255 which is too wide and sits out about 10mm, it should fit with a 235 tyre. I'll post a pic when the I have the 235 tyre fitted.
Old March 9th 2007, 23:56
Pillow's Avatar
Pillow Pillow is offline
Dang Dirk! That car is super hot! Love the exhaust!
Would you mind sharing how the exhaust was made?
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old March 10th 2007, 06:31
i will post an few pictures this week
Old March 10th 2007, 10:32
Old April 7th 2007, 21:24
Fitted up the 9" 55 et Cup 3 with a 26mm spacer on the rear with stock 1303 guard, tyre fits under nicely. I did have to pull it a touch so it clears on heavy cornering on bumpy roads. There is also minimum clearance at the spring plate and the bump stop has been cut back about 12mm. I dont think you would get a wider rim under a standard guard without substainsal modification.
Cheers
Paul
