Old February 19th 2007, 18:05
Pillow's Avatar
Pillow Pillow is offline
Biggest rear wheel possible for a stock fender?
Just wondering what the biggest wheel would be to stuff in a stock rear fender.
I am pretty sure a 7" will fit... But I was hoping to maybe try 8"
On any of these the offset is super deep (65 et) so I am not worried about pushing out too far. If anything maybe have to space it off the spring plates!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old February 19th 2007, 19:24
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
Adrian,
Not sure if largest wheel is the right thing to look at. The tire size will determine the space needed. Sure, the wheel has to fit, but the sidewalls and tread will be the main concern. I like to go to http://www.tirerack.com/tires/tirebran.jsp to check out the section width of a particular tire. You can also see which size rims are recommended for which size tire. Pretty usefull.
I have a Karmann Ghia and we all know how limiting those finder wells are.
Take care and good luck in choosing the right wheel/tire combo. BTW, backspacing is very important also as you already know.
Kelly (Cohibra)
Old February 19th 2007, 19:45
yetibone's Avatar
yetibone yetibone is offline
I'd have to say 7.5" is the widest. Sue's Bug has 9" wheels under 2" wider fenders with an inch cut off of the bump-stop landings. The wheel is about .5" from the edge of the fender, and a little less than that from what's left of the bump-stop.
I believe NO_H2O has stock fenders and 16"x??" 964 wheels on his...maybe he knows...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 19th 2007, 22:37
Pillow's Avatar
Thanks for the info guys!
Yeti, I think you are right on the money with the 7.5".
FWIW this is for an Oval and I want to keep the steal fenders. But beef it up as much as possible!
... Well I do have the 7"s already so might as well leave well enough alone.
Totally agreed about the tire size... I currently have Yoko AVIDs in a 225/50 16 which is a pretty big tire.
Thanks!!!
Adrian Pillow
Old February 20th 2007, 21:04
flat flat is offline
I've done 7's (17's) with a 235/45 tire, and 7.5's (18's) with a 225/40 tire. Both the above were +42 offsets on stock drums. I think the 7.5 is the limit, because then you have issues with the tire and the springplate.
Good luck,
www.vdubengineering.com
Old February 20th 2007, 21:41
yetibone's Avatar
Good luck,
Yeep. I totally forgot about that... I had to put the control arm/springplate nuts on the inside of the springplate, and grind a touch off of the bolt heads on Sues to be sure her Cup III's would be clear. I later found out that the grinding wasn't really necessary after I got the spacer situation right though.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 22nd 2007, 08:32
Bruce2 Bruce2 is offline
7.5" isn't the limit. Here's an 8!
Old February 23rd 2007, 10:04
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
stock
this is an 8" x 18" under stock fender
Old February 23rd 2007, 23:53
Scotts73SB's Avatar
[QUOTE=dirk.Gysbrechts
this is an 8" x 18" under stock fender[/QUOTE]
Wow.. . whats the offset on those?
Last edited by Scotts73SB; February 23rd 2007 at 23:53. Reason: didnt want the picture copied
Old February 24th 2007, 03:56
Offset is 46mm.
Old February 24th 2007, 04:09
Pillow's Avatar
Dang those 8"s really fill it in nicely!
Like Yeti and Flat mentioned, are the spring plates stock?
Thanks!
Adrian Pillow
Old February 24th 2007, 04:19
Yes, the spring plates are stock.
this is the front...
Old February 24th 2007, 23:54
Hi Dirk
They look sensational.
Are you running 2 or 3 bolt front struts and is the ET/offset the same on the front wheels? Are there any other photos of your car?
I just did a calculation on this site http://www.1010tires.com/WheelOffsetCalculator.asp and comparing a Cookie/Fuchs 7 X .. with a 23 ET you would have 36 mm less inner clearance and 10mm more clerance to the fender.
Old February 25th 2007, 04:01
Hello, I am running the 3 bolt suspension on the front but with the Remmele Front struts for more space on the innerside. The offset is in the front the same.
Old February 25th 2007, 09:55
Hi Dirk
Thanks for sharing your info, it all goes into other users databases for future use.
Nice looking car, I did a search saw some other photos.
