Hello Jason
the Pasat unit that I mentioned is not a modern rack, it's an 80's unit and reallity is that they are exactly the same at all aspects angles and dimensions except the drive shaft length (which can be shortened) and the way that is attached to the body (which also can be fixed). I cant post pictures so if you go to another thread called rack and pinion retrofit you'll see the pictures that vwbao uploaded and where it's obvius that they are identical. The only aspect that I hadn't time to check is their ratio, I suspect that the pAssat has more turns from side to side just to easy things because of the front placed engine and gearbox
Friendly
Dimitrios
