Thanks partswagen!
From what I can see on some Porsche website , maybe I can fit a 930 setup in stock 16" 911 fuchs, (304mm by 32mm front,and something like a 310mm by 28mm rear(stock 930 rear) Not to sure on the calipers as of yet. I`d like to use 996 calipers if possible.
Yes I can get those tires ! I live in Japan! I can get any low pro tire. Bridgestone ,Yokos, Pirelli they are all made for the Japanese market. Thanks for the info. If you have any pics I`d love to see them. Cheers Dean |
![]() this disc is 320mm -the caliper is the boxster 's' the disc ic mercedes on a bay hub -it dont fit in this style 16inch wheel ![]() with a 20mm sapcer it might -i have definately fitted a 16 inch front fuch on a 944 rear, -i think the stock calipers are fine, with the 20mm spacer removed -bay front studs fitted , but i then fitted 90-91 2 pot 964 rearr calipers, and i needed a spacer of 7mm - i cut the stock 944 spacer down - remember to cut the spigot in the rear |
Thread Tools | |
Display Modes | |
