#31
What kind of wilwood setup is that? I have thought of going to a different pedal design but havent really looked into it yet!
#32
#33
This is a scan of the printout of the original scan of the part. Unfortunately, the original scan was lost when the computer crashed, but at least I had made one printout. It should be close to 1:1, but if it needs to be sized, keep the aspect ratio and make the width of bottom part of the pedal 4". Throttle Pedal
#34
Thanks for the scan volkdent.
I cut this out in card board and overlaid it on my stock pedal. Looks to accommodate a 12 wide quite nicely. Thanks again. Kenney |
#35
so does anyone else have any home mode parts? the pedal is pertty cool i like the idea.im in the proccess of making my own kafer brace. right now i have all the measurements done but im waiting on the clevis rods i ordered from jegs. does a kafer brace count as a home made part? if yes then when i'm done i will post it here.
#36
my whole car's pretty much home made, filler, gaffa tape...... prob why it's always in bits
#37
I think anything you had to actually make from scratch is a home-made part, from a custom wire holder to a carbon fiber dash!
#38
ok well here's my home made dash, full of expandy foam and filler
#39
before filling it up with expandy foam
![]() and after smoothing out with thin layer of glass fibre filler then body filler and matt black paint
#40
i like it...
#41
1303R what kind of peddles are those?
#42
Looks like simple aluminum plate that's been drilled...
Kafer_Mike Build 'em fast...or let 'em sit. |
#43
yep aliminium sheet drilled and countersunk. pop riveted on, steel rivets
they look pretty cool for the cost. added couple of strips of clear skateboard grip tape to the brake and clutch pedel as they were no good with wet feet
#44
Looks good. Proof form and function don't have to cost big $$$...
